OBD2 Universal Scanner Code Reader
Old Oct 21, 2009 | 03:40 PM
TL BABY's Avatar
Just purchased one of these code readers online to run some diagnostics on my 3.2 Ive had the car parked in storage for the last 2 years and took it out about a week ago and noticed at highway speeds the TL feels like its misfiring. I have a flashing CEL at high speeds. The car still runs fast but doesnt feel like its firing on all cylinders. Another thing I noticed was at traffic light and at startup the car shakes/vibrates alot. Lastly, the transmission doesnt shift as smooth out of park to D as it did previously. I have to use the key to get it from park to Drive. What could possibly cause that? Oh yea..one last thing.. where in the car is there a slot for the scanner to plug in to? I wanna get this car back up and running smoothly. Any feedback would be greatly appreciated. Thanks in advance guys.
Old Oct 21, 2009 | 03:46 PM
Mandy's Avatar
98 3.2 Flamenco Black
Coin tray, behind it.
Old Oct 21, 2009 | 07:12 PM
TL BABY's Avatar
Thanx mandy.
Old Oct 21, 2009 | 07:14 PM
TL BABY's Avatar
Any one knows what could possibly be the cause of the rough idle at standstill?
Old Oct 21, 2009 | 09:51 PM
main70072's Avatar
Try giving it a tune up since it sat out for a long time. Your brakeswitch might be stuck, causing the transmission to not shift out of park.
Old Oct 21, 2009 | 10:14 PM
Sal's Type S's Avatar
CEL flashing means a misfire. It flashes to get your attention, if you keep driving it like that you could and will damage your cats.
Old Oct 21, 2009 | 10:15 PM
or even simpler, a fuse.
Old Oct 22, 2009 | 02:19 AM
TL BABY's Avatar
thanx for your input. I will give it a tune up. The transmission being stiff to shift out of park really bothers me.
Old Oct 22, 2009 | 02:22 AM
TL BABY's Avatar
Thanks Sal. I wont be driving the car until I get the tune up done. I have a Honda civic to play with so it wont be a problem.
Old Oct 22, 2009 | 02:23 AM
TL BABY's Avatar
Can you point me to where the fuse may be located?
Old Oct 27, 2009 | 01:51 AM
Just check the brake fuse. Usually what you can do is just turn the key forward a bit usually until when steering wheel unlocks. and before the dash lights up then pull it into neutral then and start it in neutral from there you can switch between reverse and forward till you place it in park again.
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
