My RPM's maxed out
My RPM's maxed out
yea i was driving actually just racing a friend and we had to stop but when i floored the car gas pedal all of a sudden i noticed my rpm hitting 7 then 8 and wouldn't go back up until i stop and started back up!! Is this a problem?
RPM's
Yea i hit 8000 RPM's and wouldnt like release until i let my foot off the gas but i talked to a mechanic he said that's fine the car has a powerful engine so i shouldnt worry bout something like that
~Cheers~
You wanna know what I think is happening? I think you're in over your head and you have no clue about what you're doing. You just mash the gas pedal to the floor and hold on. That is not good for your car, you or even other people on the road.
Originally Posted by Haikoo
Are you exagerating about the 8k or are you dead serious? Your redline is just below 7k so if you're actualy hitting 8k then for starters you have a problem with the rev limiter. When you over rev your engine, there is a good chance of breaking something in the valvetrain.
Update:
Yea i found out that the limiter was taken off so if i start on first gear and floor the gas pedal i can hit 7 rpms then it will then change to second gear so that kinda kool wheni get intake an exhaust i be sounding real good:P
No point in removing the limiter if no other engine work was done. Were the valve retainers replaced, or the valve springs, or the rockers upgraded to withstand higher RPMs? BTW, from what it sounds like, the limiter WASN'T removed, only the shift maps were changed. The tranny is now being told to shift at a higher RPM if you are at WOT, and that really isn't smart at the level yours is set. Another note, are you actually hitting 7K RPMs or is it around 6800? Isn't our stock fuel cut at 6800RPMs? If anything, the tranny is being told to shift at 6700, right before fuel cut, which again, isn't smart if you are bone stock.
~Cheers~
~Cheers~
i need to investigate but yes my valve springs were changed alot of work was done to the engine so who knows wat but i go get it checked out
Originally Posted by KaMLuNg
okay i need to question this... unless i have been in a black hole for a while... i didn't know there was much aftermarket support for internal components for our engines...
~Cheers~
DerrickW
11-15-2015 05:52 PM
4drviper
09-23-2015 07:42 PM
