Maintenance for our acuras
Old May 8, 2005 | 01:27 AM
2doe's Avatar
Hi,
I am trying to get a suggested maintenance schedule. I have a 1997 2.5TL. Any input is appreciated.
Oil- change the oil every 7,500, Oil 5W-30
Oil filter- change it every 15,000, but recommended every time you change the oil
Fuel filter- every 60,000
Air filter- every 15,000 or when it is dirty, If you have a k&n filter (33-2267 for 2.5) every 50,000
spark plugs- copper every 60,000, platinum about 120,000
wires, cap, and rotor- They are lifetime, so when do you know when to change them?
Brake fluid- I use dot 4
coolant- flush once a year or every 50,000
timing belt- every 100,000
transmission fluid- drain and fill every 50,000
Tires- 33psi in the front and 31 in the rear
PCV valve- every 10,000 or when you check it and it sounds like the ball inside is moving, you don't have to change.
Am I missing anything? Is anything wrong? thanks any input is helpful
Old May 8, 2005 | 11:18 AM
dubcnea's Avatar
Hurricane Game
the oil depends on the type of driving you do. your owner's manual will tell you all of that type of stuff. the wires, cap and rotor you should be able to get changed via an emissions recall. call your acura dealer and have them look up your VIN to see if it's been done yet. if not, they have to do it for free. and i woulnd't ever change the K&N filter. just get a filter cleaning kit if it gets too dirty. they have a 1 million mile warranty...which is their way of saying "you'll never need another one". everything else looks good. the PCV valve i'm not sure about.
Old May 8, 2005 | 12:15 PM
Vincent's Avatar
Keeping the same oil filter is a bad idea... Change it everytime. It's only a couple of bucks.
I don't know about the changing the PCV valve after 10K miles but yeah, if you shake it and you hear the ball inside moving than it's fine.
Old May 8, 2005 | 01:39 PM
UnsanePyro's Avatar
Registered Driver
PCV valve location?
Old May 8, 2005 | 08:27 PM
2doe's Avatar
the pcv valve is near the spark plgs area. it is a plastic 90 item and a hose is connected to it. that is the hose that you need to remove to replace the pcv valve.
2doe's Avatar
So is all the milage amount are correct?
Old May 8, 2005 | 10:01 PM
SodaLuvr's Avatar
Oil every 4-5,000 miles for conventionals, 6-7,000 for Grp IV synthetics such as Mobil 1. Longer intervals require oil analysis to confirm. Always replace your oil filter at every oil change and use a quality filter, at the minimum, a Purolator Premium Plus.
Suggested: Purolator PureOne, Amsoil, Mobil 1.
Filters to Avoid: Fram ToughGuard, Fram ExtraGuard, Supertech.
I normally recommend every 30,000 miles.
I recommend replacing paper air filters every 15-20K, since they load up with dirt rather quickly. I avoid reusable filters at all costs since they do not filter as well as paper air filters. Dirt is very abrasive to the engine, you'll notice that when you have your oil analyzed, it significantly increases your upper-end wear. (Al, Cr, Fe, Cu)
Spark Plugs and Wires should be replaced when high nitration levels are shown in the oil analysis report (poor combustion), or every 60,000 miles. (Plugs and Wires)
Every three years or 50,000 miles, use only Zerex G-05 or Honda OE Coolant.
Every two years or 30,000 miles, do three drain and refills to replace as much fluid as possible. I prefer to use Amsoil Universal ATF.
Replace it every 30K, or when the ball doesn't move. However, if there is a leak, you must replace even if the ball still moves.
Michael
Old May 8, 2005 | 10:31 PM
dubcnea's Avatar
Hurricane Game
why are you avoiding those Fram filters? mobil 1 filters are far too expensive for my taste to change every 3-4k miles. i wouldn't use synthetic if you are above 100k miles anyways (personal opinion) and i don't have the equipment to have my oil tested, so i stick to K&N for the air filtration. i've never heard of any engine going bad due to them. unsure about the abrasion...i have never seen any numbers for that, so i can't say anything bout that one.
Old May 8, 2005 | 10:41 PM
SodaLuvr's Avatar
Fram filters have cardboard endcaps, a poor ADBV, as well as sub-standard construction. The Purolator Premium Plus filter that I recommend is about $3-$4, and the Purolator PureOne oil filter is $6.
It is safe to switch to synthetic oil at any time, but I recommend running two-cycles of Auto-RX prior to switching if your vehicle has over 60,000 miles. And yes, you can switch between conventionals and synthetics at any time. Most of us on the bobistheoilguy forum swich between synthetics and conventionals most of the time for testing.
You can have your oil tested for less than $20 by a lab. If you want the differences between the labs, PM me and I'll explain to you.
The K&N filters don't work very well for many applications, and you'd simply be better off using a paper air filter. Too much dirt will cause unnecessary wear on the engine. Decide for yourself.
Michael
Old May 9, 2005 | 09:08 AM
WolfpackBill's Avatar
TL no more!
The PCV valve does not need to be changed unless needed to. Pull it out and shake it. If it rattles, then it's working. If it doesn't, then replace it.
Old May 9, 2005 | 03:08 PM
LDH's Avatar
LDH
I
After I read your first post I figured you were a member of bobistheoilguy forum.
Zonian22
Nov 14, 2015 01:20 PM
MyGuti
Sep 12, 2015 06:52 PM
lovic87
Sep 9, 2015 10:18 AM
ahsm
Sep 9, 2015 08:35 AM
Zonian22
Sep 2, 2015 08:19 AM
