lost power at higher altitude... HELP!
Old Aug 9, 2006 | 03:13 PM
kaotikvizion's Avatar
Exclamation lost power at higher altitude... HELP!
I lived in san diego when I first bought it at 118000 miles. I moved to show low in az (6000 feet above sea level) & noticed a significant loss in horsepower... can anyone help or have any suggestions?
Old Aug 9, 2006 | 03:16 PM
I gain the horses back when Im in lower elevations can I reset the ecu or what?
Old Aug 9, 2006 | 03:31 PM
wackjum's Avatar
Thinner air, less oxygen. Less oxygen means a smaller explosion and so less power.
Old Aug 9, 2006 | 11:40 PM
Go90go's Avatar
大日本帝国
Just thank god you aren't bouncing off your knock sensor, and I hope that you're using premium fuel.
~Cheers~
Old Aug 10, 2006 | 09:12 AM
Pure Adrenaline's Avatar
Dragging knees in
That's just physics. You can't do anything about it, aside from adding forced induction. When I was out in Colorado visiting my brother, my '03 Type-S was having a hard time on the mountains. I loved the moutain roads out there, but for once, I didn't mind the low flat lands of Michigan.
Oh, yeah, the car actually threw a code while on the Pikes Peak road. MAP sensor low voltage. There was such little air up there near the top that the computer thought there was something wrong with the car.
No need to reset the computer... it'll adjust by itself.
Old Aug 10, 2006 | 01:59 PM
duck97tl's Avatar
How long have you been there. I live in Wyoming (5000 ft +/-) and it takes quite a while for the processor to reset after I have been back from a long trip...Also, using the AC while at that altitude really brings the power down. Not much that you can manually do with it. Be sure, like the post above said, to burn higher octane fuel.
Old Aug 10, 2006 | 02:28 PM
arshdeep99's Avatar
Higher Altitude - Lower Octane
I've heard you can get by lower octane fuel at higher altitude (Cylinder pressures are lower at altitude due to the reduced engine breathing, so there is automatically a reduced need for high octane. ). That kind of contradicts with the advice being given here to use high octane...doesn't it?
Old Aug 10, 2006 | 02:59 PM
Go90go's Avatar
大日本帝国
Makes sense what you said, but with the Supras, my m8s were barely able to not knock while running race gas...
~Cheers~
Old Aug 12, 2006 | 02:00 AM
bustardvan's Avatar
Yup, at higher altitudes you can use lower octane fuel. At 6000ft you can use 87 octane and probably even 85.
Old Aug 12, 2006 | 02:09 AM
Ken1997TL's Avatar
At lower elevations you need higher octane, which is why you'll see 93 or 94 octane at sea level. At higher elevations i've seen 85, 86 and 88 octane.
Old Aug 12, 2006 | 08:27 PM
Go90go's Avatar
大日本帝国
?? Weird, oh well, 7Ms always had their quirks, hehe.
~Cheers~
Old Aug 12, 2006 | 11:00 PM
duck97tl's Avatar
Love your 1G. It will take care of you.
Jul 16, 2017 07:33 AM
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
