How to reset SRS code
Old Nov 11, 2006 | 03:20 PM
meazz1's Avatar
Sorry for a new post, the issue is different now.
1997 TL 2.5.
The SRS light came on few days ago. I tried to rest it but could not get the yellow plug in the fuse box to come off. There’s a tab, I squeezed it any which way but could not get it to unplug.
I took my car to the dealer and they erased the code and told that if it comes back, I will need to replace the driver side air bag.
Well, as soon as I left the dealership, SRS came back on.
I ordered an air bag from a salvage yard.
My question is, which one in the picture needs to be unplugged to reset and delete code? I thought it is # 1.
How do I unplug it? I tried but failed.
[IMG][/IMG]
Old Nov 12, 2006 | 11:58 PM
TLBaller's Avatar
see if you can post the picture again.
Old Nov 13, 2006 | 08:04 AM
meazz1's Avatar
is something wrong with the pic?
Old Nov 13, 2006 | 11:47 AM
KaMLuNg's Avatar
u try by squeezing and also using a small flathead screwdriver???
Old Nov 13, 2006 | 06:20 PM
meazz1's Avatar
I tried squeezing the tab, I have to use a flat head screw driver next.......
Old Dec 4, 2006 | 06:32 PM
kwee's Avatar
i also have the same problem with my TL. been like that for months, i tried taking the same plug out but had no luck so i gave up. did you horn died out? mine did i've been planning on taking it to a shop to get it check but no time.
Old Dec 4, 2006 | 06:53 PM
meazz1's Avatar
I finally fixed the problem, but that yellow connector may not be the right one. There's another yellow open connector ( not connected to anything) tucked under driver side dash, right below cruse control switch. I reset my SRS using that. As a matter of fact, that is suggested in the book.
My SRS came on because of a bad cable reel ( clock spring). It sits under the driver side air bag.
Old Dec 7, 2006 | 01:46 PM
kwee's Avatar
that might also be my problem but i dunno much about cars so im going to go try the reset thing today
Old Dec 7, 2006 | 03:35 PM
kwee's Avatar
i reseted the SRS thing but my SRS light is still on. so i guess i have to go to a shop
Old Dec 7, 2006 | 04:27 PM
meazz1's Avatar
after you reset, did the light go off and came back?
Old Dec 7, 2006 | 04:33 PM
kwee's Avatar
yup, it turn off and then blink 2 time and stayed on
Old Dec 7, 2006 | 07:25 PM
meazz1's Avatar
this means something hard setting the code.... get it checked asap.
Old Dec 14, 2006 | 05:03 PM
kwee's Avatar
when you brought your car to the dealer did they reset it for you for free?
Old Dec 14, 2006 | 08:36 PM
meazz1's Avatar
They charged me $80.00 to scan it and told me the code. Yes, they reset it but it came back as soon as I left their parking lot.
Jamus22
Jun 11, 2023 10:08 AM
brboy
Oct 5, 2015 11:34 AM
Skirmich
Oct 1, 2015 12:59 PM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
