How To Change Timing Belt
9th Gear
I'm going to change the timing belt on my in-laws Acura TL 2.5. I've done timing belts on other cars, but never on one of these. Anyone one know of any web sites that have instructions with pictures? Next question is do I really have to use Honda coolant? Does
anyone else make a coolant that is compatible? TIA
Swift 3 B-A-N-G-E-R
Thanks to the website acuraautomotiveparts.org
spookey,,
dont do it.. i just had my cousin work on my car (ex chrysler- dodge -jeep_ technician that opened up his new shop in East Los Angeles). He charged me $800.00 with Acura OEM parts.. for
New Water Pump
Timing Belt,
Oil Change
Oil Filter
Clean the Throttle Body
Clean the Fuel Injectors
power steering belt
alternator belt
ac belt
spark plugs
valve cover gasket
ignitino rotor
fuel filter
I think its a preety reasonable price for all that he did, and I dropped the car off at 10:00 am and he was done with it around 6:00pm
Now quick note for ALL the NOOOBs out there. In order to remove one of the parts that holds the timing belt and water pump you need a special tool. I had purchased it for my cousin when I had my Acura Vigor. It cost about 150.00 for the part and NEED it too remove the timing belt. second the first time we did it on the Vigor, it took 3 guys too be able to make enough pressure to UNSCREW the part that holds in the timing belt.. FYI. I know its a bitch too remove so be carefull to all the mechanically challenged people out there(im one of them)
So spooky save yourself some money, drive down to LA, get another hotel room Friday Night, Drop of the car and it can be done on Saturday.. (by appt only...LOL)
just a thought
PS you can email me the video to lupe@bookworm25.com
Tranny Flush
Cap and Rotor Replacement
New Water Pump
Timing Belt,
Oil Change
Oil Filter
power steering belt
alternator belt
ac belt
spark plugs
valve cover gasket
ignitino rotor
fuel filter
just a thought
Tranny Flush
9th Gear
Originally Posted by ELA.TL
spookey,,
j
j
moving while you loosen the bolt that holds it in place? I plan on using an impact
wrench, so I don't need the two other helpers that you had to loosen the bolt. I hope
the impact wrench I have is powerful enough.
you know what he tried the impact wrench with no success last time its a pain.. we had tried it which made us go and buy this tool. go ahead and try it but i do remember us trying it last time and it would not budge
Swift 3 B-A-N-G-E-R
spookey,,
New Water Pump
Timing Belt,
Oil Change
Oil Filter
power steering belt
alternator belt
ac belt
spark plugs
valve cover gasket
ignitino rotor
fuel filter
just a thought
Tranny Flush
New Water Pump
Timing Belt,
Oil Change
Oil Filter
power steering belt
alternator belt
ac belt
spark plugs
valve cover gasket
ignitino rotor
fuel filter
just a thought
Tranny Flush
I sent you the 3 video clips of the meet... hope you got them ok... and hope you can see them and post them up... i also sent them to 1fasttl... video is a bit ugly... but its video...
you know the only diff would be on the parts, i just spoke to him, but it would be somewhere around there. It would not go up drastically and still would be cheaper than what was quoted. But he said it would need to be for a saturday that way he can finish up, that day and you could use it...LOL
ill post the pics later on today...
asahrts
09-04-2015 05:55 PM
