Help! engine sputtering. Grrrr....
Old Dec 31, 2006 | 09:23 PM
isabul2493's Avatar
acurachallenged
Exclamation Help! engine sputtering. Grrrr....
Please help! I am new to this, I have a 1997 2.5TL and the engine has started to sputter while not only sitting in idle, but running as well. The check engine light has turned on and will blink on and off for a few seconds then will remain lit. Please if anyone can help I would really appreciate it.
Old Jan 1, 2007 | 06:20 AM
KrayzieDxC's Avatar
Khmer Pride
go to autozone and check for the error code first. its free
if u have less then 150,000 miles on the car go to the dealer hopefully the problem is only the emission,otherwises u pay the other costs that does not involved in emission
Old Jan 1, 2007 | 09:51 AM
TexasHonda's Avatar
The free emissions system repair and tuneup are the way to go if your mileage is < 150K.
A blinking CEL means a misfire has been detected, further suggesting an ignition system fault or faults.
good luck
Old Jan 2, 2007 | 01:33 PM
isabul2493's Avatar
acurachallenged
thanks- i am barely under 150,000mi. I will take it in to autozone.
Old Jan 2, 2007 | 01:34 PM
isabul2493's Avatar
acurachallenged
what if I didnt get it directly from the dealer??? I got it used at toyota dealership. Can the acura dealership still help me?
Old Jan 2, 2007 | 01:48 PM
KrayzieDxC's Avatar
Khmer Pride
yes, they can still help you, your car is still underwarranty from acura. no matter where you bought it from as long as its under 150,000 miles good luck
Old Jan 2, 2007 | 02:08 PM
KaMLuNg's Avatar
i would just take it straight to Acura.. as long as u r under 150k miles, as others have pointed out, you should be good.
Old Jan 2, 2007 | 03:03 PM
meazz1's Avatar
If the warranty work has not been done prior to your purchasing the car, Acura will be able to help....
Old Jan 3, 2007 | 10:31 AM
isabul2493's Avatar
acurachallenged
what if I dont know if prior warranty work has been done on my car...will acura know this? Thanks again everyone
Old Jan 3, 2007 | 12:03 PM
KrayzieDxC's Avatar
Khmer Pride
they will check the Vin # of your car to see the Maintenance
SidhuSaaB
May 30, 2020 12:40 AM
BIGxRED
Oct 19, 2015 10:47 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
