help with bumper light install
Old Jan 7, 2005 | 03:29 PM
Corby's Avatar
i can get off the side part but I cant get off the main part!! its cold and snowy outside so im not too eager to roll around on the ground. the only thing appearing to hold on the main body is a screw thing in the inside inside part of the lense. is it just a screw that im using the wrong head for? help please before it gets dark!
Old Jan 7, 2005 | 03:53 PM
LDH's Avatar
LDH
I
each lense has a screw...if that helps
Old Jan 7, 2005 | 03:57 PM
Corby's Avatar
any chance if you remember if the screw head is the same?
Old Jan 7, 2005 | 04:29 PM
KaMLuNg's Avatar
it is a phillips head screw that u are going through from the center bumper grill right??? do you have a manual??? it shows u how.... if not u need a long philips head screwdriver and sometimes dust/dirt gets in there so u gotta make sure it grabs the head of the screw... then the light should fall out after unscrewed...
Old Jan 7, 2005 | 04:46 PM
TLxRaCeR's Avatar
First Gen 3.2 TL
here a pix to go with the directions... couldn't say it any better..
Old Jan 7, 2005 | 07:13 PM
Mikes96TL03CLS's Avatar
ya two screws on each one, one is obvious, the other is way hidden. TLX shows exactly where its at
cycdaniel
Dec 17, 2019 10:58 AM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
ellisd03tls
Sep 8, 2015 04:17 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
