Had my manifold assembly replaced
The dealer found a crack in my manifold and replaced it under the warranty (which is sweet). Plus they gave me the free tune up and everything. Over a grand worth of parts plus labor. I didn't pay a dime. I love Acura!
However, there is another leak in my flex pipe (18210-SW5-A01) which they said is gonna cost $500 to replace. So my car still sounds like a tractor..I don't mind but the passengers get annoyed. So my question is... does anyone know where or how I can get that pipe replaced cheaper? Cause for that price I should be able to get me a new catback exaust system.
Registered Driver
Haikoo, they told me the same thing too. I took my car to an independent general mechanics sort of shop, and it was not the flex pipe like they said, but rather a gasket between two pieces. I got that replaced, and also I had an oil leak (where the filter housing meets the block) fixed for $110 when all was said and done.
Received 2,329 Likes
Nice, I had a hole in the flexpipe, got the pipe/resonator removed and replaced for under 100.
Nice, funny thing is I have that same oil leak right now.
Registered Driver
I don't know if you could do it yourself or not (I still haven't found the trick to getting the filter off easily) but I believe it is just a couple of rubber seels that need to be replaced, my leak was getting slowly worse and worse, but everything is fine now
Thanks for the heads up though, ima look into getting that fixed.
Originally Posted by jerseydriver
anything is better than the $4000. estimate i just got to repair my hit and run accident. i should have chased that bitch
cycdaniel
12-17-2019 10:58 AM
cak165
1G TSX Problems & Fixes
09-02-2015 09:21 AM
