H.I.D Bulb
Old May 10, 2002 | 10:30 AM
NEUKYN's Avatar
H.I.D Bulb
Anyone know how the bulb goes into the head lamp, (what part goes up,down,left ,right....etc)
Old May 10, 2002 | 11:57 AM
96TL's Avatar
Ex-Mod
Do you have an H4 style HID bulb? If not and you're trying to modify a D2 bulb, the straight peice of metal that runs alongside the bulb has to be on top.
Old May 10, 2002 | 02:44 PM
NEUKYN's Avatar
thanks.. yeah that is exactly what i am trying to do
Old May 10, 2002 | 02:47 PM
NEUKYN's Avatar
can i buy an h4 style bulb only and just splice into wires, because i got the kit from a friend who had the philips kit but traded the car and gave me the kit. the bulb that he has looks like 9004
Old May 10, 2002 | 03:13 PM
96TL's Avatar
Ex-Mod
I had that setup also. I can get those kits for $250 with 2 ballasts, 2 ignitors, and 2 bulbs. Anyway, heres a tip. Get a H4 bulb, take off the metal plate that sits against the headlight housing. If you look behind the bulb you see 3 small weld points holding it on. Once you get that off, slide it over the HID bulb, put it side by side with a regular H4 bulb and align with the capsule with the H4 filament. Get some plumbers epoxy and put some behind the H4 plate. Dont put too much because then the bulb wont lock into the headlight right.
Old May 10, 2002 | 03:30 PM
NEUKYN's Avatar
The three weld points you are speaking is holding what?
Old May 11, 2002 | 08:34 PM
96TL's Avatar
Ex-Mod
If you look behind an H4 bulb you'll see 3 weld points. Cut those out and remove the plate. then follow my directions above. Thats the cleanest and best way to do this. I taught a few people in my neighborhood and now they're all doing it. lol. Probably stealing kits also.
Old May 13, 2002 | 07:03 PM
Question
yo what type of hid do you have for your fog lights?
Old May 13, 2002 | 08:51 PM
96TL's Avatar
Ex-Mod
I dont have the factory fogs anymore, I replaced them with Hella projectors. (Mercedes SL class) If you look in my sig pic closely you'll see them. They're on in that pic but its daytime.
Old May 14, 2002 | 05:21 AM
NsX Pilot's Avatar
HEY I WANNA KNOW WHERE U CAN GET THAT HID KIT FOR 250 AND IF U CAN STILL GET EM LEMME KNOW I WANNA GET A SET FOR MY FOGS AND ANYONE THAT KNOWS WHERE TO GET THE 6000K'S CHEAP LEMME KNOW ALSO I NEED A FEW SETS.
Old May 14, 2002 | 09:30 AM
96TL's Avatar
Ex-Mod
I get them for $250 but they're D2R bulbs. I dont think those will work with your fogs.
Old May 14, 2002 | 02:52 PM
Wampum's Avatar
Which hella HID kit do you have? One of my friends is supposed to talk to his Hella sponsor sometime this month. He might be able to hook me up.
Old May 14, 2002 | 02:59 PM
96TL's Avatar
Ex-Mod
I’m pretty sure they’re off a MB SL500. They are bi-xenon BTW. I didnt hook that feature up because then every time I would flash the hi-beam HIDs the low-beam HIDs would flicker. The projectors fit almost perfectly. Its not direct replacement though. I had to modify the back part of the headlight. I enlarged the hole and drilled 3 holes through it to hold the projectors in place.
Old May 14, 2002 | 05:22 PM
how much you pay for the fog lights, explain to me how that works bens hella?
hashbrown
Feb 18, 2022 11:20 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
h22lude
Sep 27, 2015 06:22 PM
ripit
Sep 26, 2015 06:19 PM
eastcoastguy
Sep 23, 2015 06:29 AM
