THAT explains it!!!
Old Feb 25, 2005 | 02:34 PM
Cornflake's Avatar
Reppin' the T-Dot!!
THAT explains it!!!
Well ever since I had had this car, I've noticed that at about 4000 RPM the tone of the engine changes and there seems to be a little more OOMPH....I knew there was no V-TEC and I knew we had dual runners on the intake, now I know how it all works. (Just in case y'all were wonderin')
VARIABLE INDUCTION SYSTEM
For the 3.2-liter, a boost for both high-end power and low-end torque is provided by a Variable Induction System, similar to that used in the NSX. A unique two-level intake manifold-made of aluminum to save weight-provides three possible paths for air being inducted into the engine. The path is selected by three butterfly valves that are electronically controlled and actuated by intake vacuum. When the engine is running at less than 3300 rpm, air for the two banks of cylinders is strictly separated and is led through the longer of two intake paths for optimum resonance charge effect at low engine speeds. Between 3300 and 3900 rpm, the two larger butterflies open and air flows through the shorter path for best resonance effect in the midrange. Then at 3900 rpm, the third butterfly opens to provide a large plenum serving all cylinders. At this point, the resonance effect is reduced, but an inertia ram tuning effect takes over to boost high-end breathing and power output.
Old Feb 25, 2005 | 02:46 PM
Ken1997TL's Avatar
4000 rpms is the crossover, its when the engine stops purring and GROWLS.
Old Feb 25, 2005 | 02:55 PM
Cornflake's Avatar
Reppin' the T-Dot!!
'Specially with the intake...that was when I really started noticing it. I always knwo it was something like that, but now that I have seen the intake and the big-ass butterflies, I understand it a bit better.
Old Feb 25, 2005 | 03:01 PM
Ken1997TL's Avatar
The stock airbox/resonator is there to prevent the booming noise that occurs past 3000 rpms.
Old Feb 25, 2005 | 03:26 PM
Cornflake's Avatar
Reppin' the T-Dot!!
Yup. TRUST me I know. When I sold my integra, I put it back to stock. Put the airbox back, but couldn't find the resonator!!! LOL Might as well have still had the intake on, sounded pretty much exactly the same!!!
Old Feb 25, 2005 | 03:27 PM
Cornflake's Avatar
Reppin' the T-Dot!!
Just got sad....I miss my 'Teg...:'( LOL
Old Feb 25, 2005 | 06:04 PM
Vincent's Avatar
I could always tell when the extra push came from the engine. I never figured out why it took the engine around 3500 RPM to really get that push... But now I do.
Old Feb 25, 2005 | 10:13 PM
naba2002's Avatar
wow great piece of info man wtf are those rep points???
Old Feb 26, 2005 | 02:16 AM
Ken1997TL's Avatar
They're gone, people abused them.
Old Feb 27, 2005 | 11:54 AM
Cornflake's Avatar
Reppin' the T-Dot!!
it's all good. I just put it up there for you guys, no rep points necessary.
Old Feb 27, 2005 | 05:31 PM
WBroylesH's Avatar
Is that only on the 3.2?
Old Feb 27, 2005 | 08:37 PM
Cornflake's Avatar
Reppin' the T-Dot!!
Yup. 24 valve 3.2 L V6 only. I'm sure there's some fancy stuff in the 2.5 as well....
And after just having come from the auto show yesterday, I can say I still have more faith in Honda than anybody else for making great engines The new VW Jetta also has an inline 2.5L 5 cyl as the base engine now and only 150 hp. NOT exactly the same level of car, but it just goes to show Honda's ability to get more from the same displacement. (esp. since the 2.5 TL is 10 years the Jetta's senior!
Old Feb 27, 2005 | 09:32 PM
UnsanePyro's Avatar
Registered Driver
Yeah, the Honda I5 definately feels like it has more to it then the Volvo I5 did. (2.3 or 2.4L, I can't recall)
Old Mar 1, 2005 | 12:15 PM
DRH's Avatar
DRH
Don't worry about those Cornflake...I took those out
Old Mar 1, 2005 | 12:27 PM
Cornflake's Avatar
Reppin' the T-Dot!!
HAHAH....thanks Brown....I didn't think I needed them!!
saberlove
Mar 11, 2021 09:29 AM
knight rider
Mar 4, 2016 08:59 AM
thegipper
Sep 28, 2015 01:01 PM
jmaxima03
Sep 27, 2015 10:22 AM
phillyguerrilla
Sep 26, 2015 11:27 AM
