Engine Tremors
Old Jul 26, 2009 | 12:26 AM
SurfingScotty's Avatar
2007 6SMT Type-S
Engine Tremors
If I don't drive my car for a couple of days, my car will shake at idle speed for about a mintue or so. It's enough to make me nervous. It's been doing this for about a year now, but only when I don't drive it for at least 2 days. After it "warms up", it's fine.
Any thoughts?
Old Jul 26, 2009 | 01:38 AM
DarkNinja75's Avatar
Default
No idea, but mine does the same thing. It's especially bad if I turn the A/C on since the engine is working harder. I haven't worried about it though. While it shakes, it doesn't stall, and the RPMs stay steady.
Old Jul 26, 2009 | 08:55 AM
DAiNiUS's Avatar
Same with mine, but I'm not too worried though. It does this more often in winter when it's cold, but in summer OK.
Old Jul 26, 2009 | 10:07 AM
TexasHonda's Avatar
Shaking usually means a miss. You can confirm by listening to the exhaust, where if it's a miss you'll hear a putt-putt-putt,,, as the missing cylinder opens to the exhaust w/ no-fire. This would primarily be caused by poor spark plugs on V6 w/ Coil-over-Plug ignition.
Problem could also be a dirty throttle body starving engine for air (very low idle speed) during cold starts w/ possible idle air control valve sticking closed also. Cleaning idle air control valve, throttle plate (both sides, and throttle body bore may may a huge difference.
good luck
Old Jul 26, 2009 | 11:00 AM
TLin401's Avatar
'13 Hyundai Sonata
If you idle is low then all you will have to do is clean the throttle plates and bore and the idle will go back up.
Old Jul 26, 2009 | 12:28 PM
2007 6SMT Type-S
good luck
Thanks for the advice. I was reading earlier about cleaning the throttle body, and was planning on doing that today, as I've already removed my intake box. One question: I need to take off the hose that connects to the intake, and clean all around that, correct?
I'll have to listen for the exhaust sounds next I start it up. I changed my spark plugs about 1 year ago and have only put about 6,000 miles on since, so I'm not sure if that's the cause on my car. I'll clean the intake manifold and see if that works.
Thanks again!
Old Jul 26, 2009 | 12:42 PM
TLin401's Avatar
'13 Hyundai Sonata
Yes you have to remove the tube to clean the throttle plate and bore. It is very simple and doesn't cost more than $5.
Old Jul 27, 2009 | 12:40 AM
bigwerm187's Avatar
Str8 Home built
dam that stops the shaking lol.. i dont drive my car at all... ive had it for 2 years and ive put 1000 miles on it.. but i do take care of my car tho... so yeah am try that to seeeee if it works... its tha same thing for a 2.5......?
Old Jul 27, 2009 | 07:02 AM
andrew070489's Avatar
i beleive the 3.2's might mis on purpose to heat up the cat faster to be more fuel efficient. if the 2.5 idles like that look for white smoke it could be your head thats what mine did before it went.
Old Jul 27, 2009 | 08:45 AM
2007 6SMT Type-S
I took the whole intake apart last night and cleaned everything. I disconnected all the hoses and cleaned everything with carb cleaner. It was a little difficult starting the motor after that and it idled really crazy for about 15 miles. After that, it was back to normal...probably burning up all that lose dirt and excess carb cleaner. I want to see if that stops the shaking.
Old Jul 27, 2009 | 11:54 AM
Mandy's Avatar
98 3.2 Flamenco Black
It is close to using seafoam....I heard that thing is good.
Old Jul 27, 2009 | 02:19 PM
TLin401's Avatar
'13 Hyundai Sonata
Seafoam FTW!
Old Jul 28, 2009 | 08:34 AM
2007 6SMT Type-S
I cleaned the intake really well and this morning, the tremors were back.
Old Jul 29, 2009 | 12:42 AM
bigwerm187's Avatar
Str8 Home built
after i seafoamed my car it started to smoke a little bit.. so idk if the seafoem out of my motor yet.. cuz i dont drive my car at all that much so.. yeah what do u mean it could be the head..? like it needs to et rebuild or what.....???
Old Jul 29, 2009 | 12:47 AM
Default
I Seafoamed my engine. Still shakes occasionally. YMMV.
Old Jul 29, 2009 | 12:49 AM
bigwerm187's Avatar
Str8 Home built
after i seafoamed my car it started to smoke a little bit.. so idk if the seafoem out of my motor yet.. cuz i dont drive my car at all that much so.. yeah what do u mean it could be the head..? like it needs to et rebuild or what.....??? also i checked my oil and there is nothing getting in to my oil.. and when i drive my car far places it goes away but after i seafoamed it i havent realy drove it at all juss like down the street and thats it. i think seafoam is still in my car cuz it never used to do that at all. but when it smokes its just a little bit tho..
Old Jul 29, 2009 | 06:59 AM
^ after you do the seafoam and start it up you are supossed to run the engine until it's clear of smoke. if you are still getting smoke even now then you are burning something. seafoam will not just linger around for a while. if its white smoke your burning coolant, blue smoke and its oil. most likely since your confusing the smoke with seafoam its burning coolant, does the car smell kind of sweet? fixing this problem involves replacing the head gasket. i would do it yourself to be honest. i replaced my engine instead but i should of just build it up. oh well either way it needs to be fixed, and dont let the engine heat up to hot or you wont have another option besides new engine.
Old Jul 30, 2009 | 05:12 PM
bigwerm187's Avatar
Str8 Home built
o yeah i know what your saying. i havent put coolent in my car in a very long time but i always check my oil and coolent. if it was burning coolent wouldnt it be getting low cuz my coolent aint low at all and my car doesnt not over heat.
Old Jul 31, 2009 | 08:07 AM
then dont worry about it, as long as your not loosing either one. loose elsewhere. maybe its an injector
SidhuSaaB
May 30, 2020 12:40 AM
BIGxRED
Oct 19, 2015 10:47 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
