Eibachs and BIG sub boxes - WHo's got it?!
Reppin' the T-Dot!!
1 Post
OK guys, need some info from people with Eibachs Pro kit springs and big systems in their trunks. I just replaced the rear tires on my 18's last night and they are rubbing, and the springs aren't even installed yet!! This is nuts. I have a HUGE box in my trunk, so the ass end already sits lower than it should that is my question. For those of you with Eibachs AND systems who had the SYSTEM first. Did putting the Eibachs on actually lower the rear a lot from where it was laready lowered to with the system? I am hoping that the back end won't actually drop that much cause the new springs are stiffer so that should help even though they are a bit shorter. My rims have a friggin 45 offset so they REALLY shouldn't be rubbin without the springs on yet!!! Let m eknow guys, thanks. Otherwise out comes the baseball bat.....
I had the box first and yeah it does lower the back a bit. I would suggest "shaving" your fenders. I say shaving because its plastic back there and you cant roll it so you will have to dremel it off. That what i did. I have 18x7.5 +48 with 225/40 18s and no rub. I had 225/35 19s on before and it rubbed but im pretty sure it was due to the offset of the wheels (+40)
Reppin' the T-Dot!!
1 Post
Under the rubber bit its plastic I took it to a shop that does Mercedes and sh*t and the guy said it had to be shaved and couldnt be rolled just letting you know man so you dont try something bad. So you know before you try check it out first that al im sayin
Reppin' the T-Dot!!
1 Post
Reppin' the T-Dot!!
1 Post
Originally Posted by Lof8
hey Cornflake, how did it go? Any tips? I'll be rolling mine soon too.
Thanks, Andy
Thanks, Andy
Reppin' the T-Dot!!
1 Post
Yes, but it's from my '98 teg. fit that car ok with the setup I had on that thing. Now I gotta totally re-do my trunk to make it look good for the TL. Those damned strut's in the trunk are such a PITA!!!
emailnatec
29
09-28-2018 04:27 PM
