ECU Wiring - differences
Old May 13, 2005 | 02:16 PM
Cornflake's Avatar
Reppin' the T-Dot!!
Ken, One last question. WHen you first setup the Type II, your uncle just changed the harness and plugged it into the stock ECU, correct? Then when you swapped ECU's, you just simple unbplugged the TL one, and plugged in the Legend one correct? I have my Type II ECU now. It is missing one plug that the TL one has. I can't get the exact diagram I need so I am guessing that if you just swapped the ecu's with a cimple unplug and plug then I SHOULD be ok. Please let me know as soon as you can bro, thanks.
Old May 13, 2005 | 04:23 PM
Ken1997TL's Avatar
I'm calling him when he gets back tonight about this. But that sounds about right!
Which diagram do you need?
Old May 15, 2005 | 09:28 PM
Cornflake's Avatar
Reppin' the T-Dot!!
I don't so much need the diagrams, i have all those. I just need to know if when you swapped it was a simple swap (for the ECU) and what that extra plug was for on the TL ECU. Thanks bro.
Old May 17, 2005 | 08:48 AM
Cornflake's Avatar
Reppin' the T-Dot!!
Any luck with this one Ken? Did the Legend Type II ECU just swap the TL one straight plug and play? Let me know, thanks!!!
Old May 17, 2005 | 08:49 AM
Cornflake's Avatar
Reppin' the T-Dot!!
Basically what I need to know is if the wiring is the same. If your mech. just simply unplugged the TL ECU and plugged in the Legend ECU then yeah, everything should be easy and I can just go get my car back tonight! Otheriwse I gotta verufy all the wires and that is gonna take ages....
Old May 17, 2005 | 10:15 AM
Ken1997TL's Avatar
I asked, he doesnt remember
I went over it on the phone with him, trying to jog his memory but... to no avail.
Sorry man. I'd take this one carefully as I dont want anything getting ruined/wiped.
Old May 17, 2005 | 10:19 AM
Cornflake's Avatar
Reppin' the T-Dot!!
Unhappy
SHIT...alright man, thanks for the help anyways bro. I think I may just plug the effin thing in and pull the pin and see what happens!!!! (Won't REALLY do that, can't afford another ECU!!!)
TypeS860
Jan 10, 2026 11:11 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
SUPRMN84
Oct 7, 2015 09:46 PM
Skirmich
Oct 1, 2015 12:59 PM
eastcoastguy
Sep 23, 2015 06:29 AM
