Does anyone know how to add a custom grill to 3.2 TL?
I have seen some around. I was told to get sumthin like gutter guard from Home Depot and then take off the front grill and put the gutter guard over it. How do u take the grill off? any ideas? thanks
I saved this from a old post before. Never got a chance to do it yet. Let me know how it goes. BTW like what you did with the dashboard....how did you do it?
Here are the instructions on how to make your own grill and the parts you will need.
parts:
1) gutter guard. they sell this stuff at home depot, just ask any dude and they'll tell you where you can get it. probably around 6 bucks.
2) have something to cut the gutter guard with. i used a dremel, which is like a little saw, it's nice cause it made precise cuts. if you're really ghetto you can probably use wire cutters, but then it might not look as good or clean. you'll find out later.
that's all you need for parts. let me warn you that it takes a couple trys to get it looking nice. reason being that our grille is curved.
ok here we go
1) unscrew EVERYTHING. including the "A" which ironically is held together by like 10 screws.
2) ok now bring over the gutter guard and cut off the length of the grille.
3) you will see two plastic centering things for the "A", i for got the exact details. but i used that as a guide. you might have to widen a link or two of the gutter guard so that the plastic tabs can fit in. now screw the "A" back into the grille. At this point you should have the chrome rim off. the chrome rim is what's going to hold your mesh in.
4) now's the fun part of carefully cutting the edges of the gutter guard to the shape and size of the grille opening. be patient cause if you cut off too much, you'll have to start over. just push the gutter guard near the edge and eyeball where the chrome piece goes and leave a little more.
5) assuming you got that part all done. don't forget to cut out places where the chrome tabs go. i was stupid and forgot about that and broke off a couple tabs.
6) next you screw the chrome piece back in, hopefully securing the gutter guard.
7) stand back and see whether the gutter guard seems to be level and not slanted to one side or another. if you're happy with your work, then put the grille back on the car.
whew, this little project should take you a whole afternoon. good luck
parts:
ok here we go
hey thanks a lot! as for the guages, i learned how to do it from 96tl. i also converted my climate controls and every other light to blue as well. used blue 194 leds for the back of the speedo, and then 2 blue 5mm leds for the needles.
Pham Alvan
03-16-2016 09:17 AM
soupi
14
11-15-2015 11:15 AM
