Check engine light
Old Nov 21, 2005 | 06:44 PM
ceo22's Avatar
Check engine light
I have a 97 Acura 2.5TL with 117k miles. I faithfully put 93 octane in the tank during the life of the car and by mistake last week filled up with 87. Now my check engine light has come on. Will the light go off once I burn off the 87 octane and replace with 93 or is this a sign of a bigger problem?
Old Nov 21, 2005 | 07:28 PM
meazz1's Avatar
After few trips, it will go away. don't worry about...
Old Nov 21, 2005 | 08:31 PM
ceo22's Avatar
Thanks..but do you mean a few more trips after I change back to 93?
Old Nov 22, 2005 | 06:52 AM
praxiis's Avatar
Mine has been on for a while now (more than a year) - dealer sez I need an engine cleaning ($$$), so you're probably on the way to the same deal. It's really only affected my gas mileage. I haven't got it fixed because I spent too much money on a house :P. Apparently there's a fuel-line cleaner that might help if you put it in at 1/4 tank...
Also - do yourself a favour, keep with the high octane. Car runs like shiz without it .
Craig
Old Nov 22, 2005 | 07:50 AM
meazz1's Avatar
If it came on because of the gas issue, few more trip should cure it.
Old Nov 22, 2005 | 06:48 PM
TexasHonda's Avatar
Why not pull the codes by shorting the Service Check Connector and know what caused the CEL? I run regular in my 2.5TL all the time and it runs smooth as ever w/o any CEL. It coudl be something that needs attention.
I looked through the codes list and there does not appear to be any code that would correlate w/ use of regular fuel. Engine controller adapts by retarding timing slightly when pinging is detected, which will reduce fuel mileage for highway driving by some amount. I've never detected any pinging so I don't know if my timing is retarded or not. I get about 25-27 mpg highway and about 22 mpg around town.
I seriously doubt if regular gas is cause of your CEL.
good luck
Old Nov 22, 2005 | 07:11 PM
Ken1997TL's Avatar
Agreed, regular gas wont cause problems.. you most likely have another issue, such as an oxygen sensor thats out.
Old Nov 22, 2005 | 07:52 PM
meazz1's Avatar
I always had that problem. Everytime I put regular gas, CEL came on. What ended up happening was a damaged OX sensor.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
