check engine light....
Old Dec 29, 2003 | 12:07 AM
changed spark plugs, air filter and pvc valve. car started and ran fine. after a few miles the check engine light came on. any suggestions as to what's going on?
Old Dec 29, 2003 | 12:32 AM
oulaw29's Avatar
Attorney- Will Sue 4 Food
My 97 3.2tl s check engine light came on like that when I ran out of gas and ran the injectors dry. It stayed on for like 2 months. I was just too lazy to pull battry wire and reset.
Old Dec 29, 2003 | 11:13 AM
Mikes96TL03CLS's Avatar
Could be 25 diff things. You'll need to take it into a shop if it continues, and have them run a test.
Old Dec 29, 2003 | 02:15 PM
982.5TL's Avatar
All about JDM
It could just be your O2 sensor. That seems to be a common occurance on some TLs.
Old Dec 29, 2003 | 02:48 PM
try just reseting itby unhooking the battery it could just be something stupid if that doesnt work do what mike says and take it into a shop
Old Dec 29, 2003 | 07:31 PM
Take it to any autozone store, they will test it out for free. They have an OBD(on-board diagnostic) scanner. They will give you a printout of the trouble codes. The OBD plug is located under the ashtray(change tray).
Yikes
May 3, 2021 04:29 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
Billu99tl
Sep 13, 2015 11:30 AM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
