Burning Oil
Old Aug 4, 2013 | 10:24 AM
planoacura's Avatar
7th Gear
Burning Oil
Hello to all, my 1996 acura 3.2L Tl with over 160K miles is burning oil. I am not the driver. I have been told that at stop lights, while idle and acceration you can see a little smoke (Blue in tent) from the tail pipe. Checking the oil level you can tell it is desapearing. Also, I have been told by the service department that there are oil leaks on the engine. But you cannot see any Major stains were it sets. I have research and a lot of threeds but have not figured out the real problem.
It could be the rings, I have been told that this engine a type C32A is prone to have bad rings at high milage. Can any real mechanic out here confirm this?
I have fround out on other threads it could be the valve seals? Someone even sugested it could be a cloged up PVC valve, putting more pressure on the system and forcing oil where it should not go. Has any mechanic had this type of problem?
I really need some good advice from mechanics or owners of this vechicle that have or had this problem. My state inspection is due and I do not think the car will pass.
FYI The service has been keep up, but the (dealer) service advisor sugest that I do not repair and just keep adding oil untile it (engine) dies.
Any thoughts on burning oil?
Old Aug 4, 2013 | 11:37 AM
white2.5tl's Avatar
check your coolant for oil. it could be head gasket
Old Aug 4, 2013 | 06:12 PM
adventurecrv's Avatar
Oil leaks in the engine compartment common issues are the valve cover gaskets, and oil filter housing seal.
Old Aug 5, 2013 | 06:52 AM
HP11's Avatar
97 3.2TLPrem(Sold 3/7/14)
Doubtful because he said the smoke is blue in tent (tint). That's oil not coolant i.e. bad rings or valve seals/guides or anything that allows oil to get into the combustion chamber as speculated in his second an third paragraph.
Old Aug 5, 2013 | 09:00 AM
planoacura's Avatar
7th Gear
Hello "white 2.5tl. Thank you for your input. I do not think it is head gasket. I agree with "HP11", because of blue tent color of smoke. But I will check the radator tonight, it is high mileage and could be more than one problem. I will post back findings.
Old Aug 5, 2013 | 09:09 AM
planoacura's Avatar
7th Gear
Hello "adventurecrv", Yes I agree with you on common oil leaks. thank you for your response. At this time I do not know if there is a leak at the oil filter gasket. But I do know the valve cover (acura calls it a rocker arm cover) gasket needs atention.
Old Aug 5, 2013 | 09:23 AM
planoacura's Avatar
7th Gear
Hello "HP11", I bleave what you wrote is dead on correct. Thank you for your response.
Some how, some way, oil is getting into the combustion chamber. I am hoping that a member or members with high mileage 3.2l have been down this road and would post. Thanks again for posting.
Old Aug 5, 2013 | 04:33 PM
I would head for a shop and get yourself a compression test. That would be a great starting point...
Old Aug 6, 2013 | 11:02 AM
planoacura's Avatar
7th Gear
In response to "white 2.5l", I did check the raditor and did not see any signs of problems. I also looked for any coolent leaks and did not discover any. Thanks for posting
Old Aug 6, 2013 | 11:12 AM
planoacura's Avatar
7th Gear
Hello adventurecrv, I have been looking around for a good shop. A compression test might not be conclusive. But I do know that I will have to try it. Thank you for posting.
IBankMouse
Jun 13, 2020 12:53 PM
calrow
May 3, 2017 10:21 PM
Thuneau
Oct 3, 2015 04:19 PM
jubikej
1G RDX Problems & Fixes
Sep 30, 2015 01:13 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
