Brake Pads replacement
Old Mar 25, 2003 | 09:04 AM
Mandy's Avatar
98 3.2 Flamenco Black
Need help.
My Brake wear indicator is whining hard!!!!
1st time to replace Brake Pads, I need directions. Fairly easy to do?
Checked with the dealer, costs $60 for the front Pad set. I will attempt to replace myself.
Should not be hard, but I need somebody's advise.
Thanks a bunch in advance.
Mandy
Old Mar 25, 2003 | 11:36 AM
TLBaller's Avatar
i bought AXXIS brake pads from A&H motorsports. they're the cheapest i found on the net. i received the pads in poorly condition but all the other TL'ers who bought axxis pads (from diff shops) told me theirs came in bad condition as well. i haven't gotten any dust on my rims ever since i put them in!
mviper007's Avatar
Lightbulb
NOT HARD,,, BUT MIGHT BE A LITTLE TUFF IF U NEVER DID BRAKES BEFORE!!!!!!TRY TO GO TO A PLACE THAT SELL'S PART'S CHEAPER THAN THE DEALER LIKE PEPBOY'S///R&S STRAUSS////KAR PART'S OR SOMETHING LIKE THAT ....I DON'T KNOW WHAT IS AROUND U SO U WILL HAVE TO SEE.....NOW IT IS MAKING NOISE THAT COULD BE BAD THE ROTOR'S MAY NEED TO BE CUT OR REPLACED ????????U WILL HAVE TO SEE HOW MUCH IS LEFT ON THE ROTOR AND IS THE ROTOR STILL SMOOTH ?????THOSE FRONT'S HAVE TO BE PRESSED ON AND OFF 60.00 COULD END UP TO BE 300.00-400.00 IN PART'S AND LABOR!!!!!!!!!!
Old Mar 25, 2003 | 11:39 AM
TLBaller's Avatar
yeah thats true, if you come to a stop and hear "screeching" sounds then your "almost gone" brake pads are eating up your rotors. rotors cost a lot to replace so you can save money by resurfacing them. its a whole lot cheaper. next time, if your thingy screeches, change pads ASAP!
Old Mar 27, 2003 | 02:07 AM
TouringLxry's Avatar
Pads are very simple if you have ever done them. The TL pads were the easiest I have ever had to do, just make sure that you have the tool to screw the piston back into the rear caliper (the piston has a big + on it and the way it adjusts is to unscrew, so with new pads you must screw it back in. Very simple.
I however had both of my right rotors wear down until they were very thin, added a rust tint to my paint!
Old Mar 28, 2003 | 01:31 PM
Mandy's Avatar
Did my pads, last night. Quick and easy.
14 mm Bolt on the front and 12 mm on the rear.
But I forgot to put the grease in between the cylinder and the shim......maybe it will not hurt.
It took longer to raise the car, unbolt the wheel than replacing the Pads. Lucky for me, the wear indicator just started to kiss the rotor.
Now, I feel a nice solid brake!
Thanks all for your help!
mada51589
Jan 9, 2025 04:40 PM
nanos
Nov 12, 2015 08:41 PM
gqdabien
Sep 8, 2015 11:41 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
nishant11
Sep 2, 2015 10:34 AM
