bought remote unlock fob on eBay, cant get it to work - help
Hi, for my 1996 TL I recently bought this :
http://cgi.ebay.com/ebaymotors/ws/eB...0872465&rd=1,1
i followed the instructions and it didnt respond at all. is this what other 96 tl owner's fobs look like? im pretty sure i did everything the instructions said.
do they all look like this : http://cgi.ebay.com/ebaymotors/NEW-A...QQcmdZViewItem
Depending onw how much you want to spend
you can get a remote start/ alarm system for under a $100
this will give you keyless everything AND remote start.
to spend $30+ with shipping and handleing and having it piss you off becuase it doesnt work isnt worth it in my opinion.
You can get a really cheap alarm and even that will have keyless entry and a set of new remotes
actually, iirc, didn't the key fobs for the first gen TL look like this...?
http://cgi.ebay.com/ebaymotors/96-97...QQcmdZViewItem
thats a honda accord 98-01 remote!!..falses auctions
edit:i knowdist you have a 2.5tl car, i thought that car dont have keyless. only 3.2tl have keyless remote and not 2.5tl correct me if im wrong i readed thur these forums that only 3.2tl remote will only work
here wat i found of a write up bu the moderators:
Here are the instructions for the 3.2 (I cant find any for the 2.5, i don't think it is programmable, the 1998 2.5 is the exception, it uses the same setup as the 3.2)
1. Open the driver’s door.
2. Push up the driver’s door master power door lock to
the unlock position. Hold it there for the rest of this
procedure.
3. Insert the key in the ignition switch, then remove it.
Repeat this four more times within 10 seconds.
(Steps 3 and 4 must be completed within 10
seconds, or the system will exit the programming
mode.)
4. Insert the key in the ignition switch. Make sure the
power door locks cycle to indicate that the system
has entered programming mode.
5. Press the “LOCK” or “UNLOCK” button on the
transmitter. Make sure the power door locks (all
except the driver’s door) cycle to indicate that the
transmitter has been accepted.
6. To program a second transmitter, press its “LOCK”
or “UNLOCK” button within 10 seconds.
7. Release the master power door lock switch to exit
the programming mode.
procedure.
mode.)
~Cheers~
Originally Posted by daemonicus
these days, you're just as safe without an alarm as you are with one.word..
sweet steal it anyhow. ill justy make out like a bandit off my insurance company...
all alarms are good for are the options like remote start, power truck release, window roll up, and all that other fancy jazz.... and getting you out of bed running outside with the mossberg at 4 am because some fuckin cat ran across the hood.. I mean if you are gonna jack my shit, at least let me sleep in peace. All your gonna get anyways is some tarnished pennies and a bunch of ripped antiflag and cage cd's i already have copies of anyhow. Take the cd player too, ill just get a reciept for a better one. shrugs,,
rubbers dont prevent aids just like those dumbass noise makers dont prevent your shit from being bogarted.
tman570
Jun 11, 2019 07:56 AM
Trplezero
Sep 3, 2015 10:25 PM
1996, 32, accord, fcc, fob, gj808e6001, honda, id, instructions, keyless, program, programming, remote, tl, unlocker
