96 - 3.2TL - Check Engine Light
Ok, last night when I was driving home, the check engine light came on. I have about 1/3 tank of gas, & filled up last time, so it's not a loose gas cap.
What could it be?
Is there a way to check the codes? In a previous life I had a 90' buick century & if you took a paper clip, unfolded it, & touched terminals 2 & 8 below the steering column under the dash, with the key in the on position, it would flash the code sequence via the check engine light.
Thanks in advance,
Dale
What could it be?
Thanks in advance,
Dale
HeloDown
09-08-2015 06:51 PM
