19 inches wheel
Old Aug 15, 2002 | 08:58 PM
Question 19 inches wheel
who in this forum has 19 on a 3.2 tl ,can u please tell me what off set to get with out rubbing,i have a 3.2 tl 96 with ground control and stock shock. please post pics up or email me at reynoso2299@msn.com thanx fellas...........
Old Aug 16, 2002 | 12:29 AM
Colt45's Avatar
B A N N E D
hmm
44 offset
7.5 inch wide rim
225 35 19 tire
with this on my 98 tl with groundcontrols i can drop it all the way in the front and rear. even with it down all the way it does not rub in the rear and the front only rubs when turning
good luck,
colt
Old Aug 16, 2002 | 01:27 PM
dbox's Avatar
whoXwanXsum
i had 19x8 with a 45 offset on my 96 3.2
roll your fenders and you will be fine. i had axis se7ens
Old Aug 19, 2002 | 04:50 PM
thanx alot fellas no pics?
Old Aug 21, 2002 | 11:20 PM
somebody please post a pic of 19' in there car
Old Aug 22, 2002 | 12:40 AM
valuetl's Avatar
Has anyone tried to run 19's on a first gen. with a high offset???
Old Aug 23, 2002 | 08:17 PM
hey mike you back i have a question for you i wanna get the air bag suspension on my car but i also want to put 19 on it you think is possible? oh yeah thanx alot for the black housing they look great the only thing is that the corners light hole is a little to big but i did some custom work and it came out nice so they do fit from a 2.5. pls email me the right off set for the 19 and you said it was3000 with shipping for the airbags for a 3.2 skipper. thanx
Old Aug 29, 2002 | 07:33 PM
HELP
Old Aug 29, 2002 | 09:08 PM
valuetl's Avatar
Miguel tried calling you a couple times about the turn signal plug issue. I have plus that will fit the hole in your headlights! The bad news is the TL wiring plug is not the same as the inspire. I've been working with scott here in HI to remedy the problem and he found a way to do it. Luckily they both use the same 3 wires. Just need to cut the back of the inspire pulg to get the TL wiring plug to go on. If you need the plugs for your housings I will send them to you N/C. For anyone else with black housings I ordered extra plugs for the turn signals. Also use a 1157 double filament bulb for them. You can use bags and 19's the skipper showcar (white one) had the same setup. Just make sure you get the right offsets on your wheels.
Old Aug 29, 2002 | 10:26 PM
is there any way to fit 20"s? I want to get spinning rims but they don't come in less than 20
yvr_tsx
Sep 15, 2015 01:14 PM
EE4Life
Sep 11, 2015 10:13 PM
mtl_ilx
Sep 3, 2015 09:58 PM
nuldabz
Sep 3, 2015 05:49 PM
mtl_ilx
Sep 3, 2015 09:48 AM
