Wtf....
Old Nov 29, 2012 | 06:05 PM
96Rlblack's Avatar
5th Gear
Thumbs down Wtf....
I had my 96 rl out earlier today driving around just fine I was watching my gas gauge read around half a tank of gas as i was coming to a stop it shut off... restarted no problem, idle find before it shut off did it to me three more times on the way home had only gone 170 miles on the odo. i know my gauge is off a little but there is no way its off a half a tank.. so i went to the station and figured i would top it off.. it only took 10.2xx gallons of fuel meaning there was still around 5 gallons in there why is the car shutting off? what is the issue here? I dont wanna give up on this car but it seems to be one issue after another
it has 198,xxx on it
Old Nov 29, 2012 | 09:57 PM
3.5RLv-tec?'s Avatar
If it still has gas left then it is not relating to the gas tank, or maybe a clog fuel filter. Is your idle rough? You might want to check the little tube( one end is connected to nothing) on the passenger side near the ignition coil. You will be surprise if this little tube crack or loosely connect the car will have rough idle and it will not start. Other possibilities are the main relay and get a tune up lol. Remove the ignition coil and check the spark plug have oil, thats just my though. Other then that, the car is very solid Good luck.
Old Dec 7, 2012 | 01:32 AM
Jimmay's Avatar
Did you ever figure out the issue? My car recently started doing this. Im about to throw in the towel and sell this car.
Old Dec 7, 2012 | 10:43 PM
Ken1997TL's Avatar
Fuel filter? Bad fuel pump?
Old Dec 10, 2012 | 04:35 PM
pmendoza502's Avatar
check your main relay
Old Dec 12, 2012 | 03:24 PM
96Rlblack's Avatar
5th Gear
no i did not figure it out still having the same issue car is going to the crusher tomm..
Old Dec 14, 2012 | 10:22 PM
Jimmay, where/how did you run the power cable for the aftermaket amp. I couldn't figure where to run the cable, help!
Old Dec 15, 2012 | 11:49 AM
MyNameIsEarl's Avatar
If the car hasn't gone to the crusher yet. Can I buy your sunglass holder off of you?
Ratheruneeq
Aug 21, 2015 09:44 PM
01clsstock
Nov 6, 2013 09:13 AM
BustedJack
Apr 27, 2007 10:01 PM
TommysTLtypeS
Dec 30, 2005 08:35 AM
phil2
Console & Computer Gaming
Mar 26, 2004 08:03 AM
