Window Switch
Old Dec 5, 2010 | 03:59 PM
max2's Avatar
4th Gear
Window Switch
Hi guys, I have 99 RL and the two front window switches on the driver' control don't light up anymore, but they still function, and the switches for the back windows work and light....could that be a fuse or a light bulb out? Any susgestion is greatly appreciated!
Old Dec 6, 2010 | 03:00 PM
OLD_HATCH's Avatar
that's just a small lightbulb in the switch out. If it bothers you enough to fix radio shack sells 12v micro bulbs that will fit into the oem light base for a dollar a pair.
remove door panel, then remove switch from door panel.
Old Dec 6, 2010 | 08:28 PM
max2's Avatar
4th Gear
Thanks for the info, I appreciate if I can instructions to remove the door panel..........Thank you in advance!
Old Dec 6, 2010 | 10:18 PM
jerm1386's Avatar
60mph Soapbox Racer
the instructions for removing the door panel are in the service manual
Old Dec 8, 2010 | 01:01 PM
max2's Avatar
4th Gear
I appreciate you guys, did anyone used those 12v micro bulbs from radio shack, do they work good as the ones from the dealer?
Old Dec 8, 2010 | 01:15 PM
OLD_HATCH's Avatar
I've used them in all my Hondas. They work just like oem.
le^2
Mar 17, 2026 05:06 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
eastcoastguy
Sep 23, 2015 06:29 AM
