Temperature sensor issue?
Old Jul 15, 2011 | 02:04 PM
9000revs's Avatar
The last couple of mornings as I drove the work (auto temp set to 72) I noticed the heat kicking in a bit more than usual (can feel the intensity, outside temp probably 56-58). Before it would start off with mild heat and then turn colder when the set temp is reached. On both situations, turning the auto off/on seems to have fixed the problem. Not sure if this is due to one the exterior temperature sensors going bad. Later in the day seems to be fine but outside temperature is also higher by then (70-78). Any ideas? How much would something like this cost to fix? Thanks.
Old Jul 15, 2011 | 02:23 PM
Ken1997TL's Avatar
Remove the terminals on the battery, that might reset it. Write down your radio/navigation anti-theft codes first.
If that doesn't work, it might be a temperature sensor issue. Possibly the interior one to the right of the steering column.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
