Tachometer causes oil light warning
Old Oct 19, 2021 | 08:53 AM
Ytown97RL's Avatar
7th Gear
I have a 2003 RL with 103,000 miles but this situation has been happening for quite a while. The tachometer will stop working while driving but it will start working again after a short period of time. When it starts working again, the oil light will start blinking red. The first time this happened I didn't realize the tachometer had stopped and started. I only noticed the oil light flashing and stopped to check the oil level. After you shut the engine off and then restart it, the tachometer works and the oil light is off. There is no oil problem and the fuses all tested good. Any ideas?
Old Nov 2, 2021 | 09:39 PM
Babafats's Avatar
instrument cluster issue was it ever opened for it sounds as if its shorting
Old Nov 4, 2021 | 12:37 PM
Ytown97RL's Avatar
7th Gear
No. The instrument cluster has never been opened. I did hear years ago that this model has a problem with water getting into the fuse box which might be the cause of this problem. Has anybody also heard of this?
Old Nov 4, 2021 | 02:37 PM
Is it ONLY the tach or the entire cluster? Sounds like there might be some loose wires that's causing the tach/oil light to disconnect and then reconnect. Doesn't the oil light blink when you first turn on the car?
1st timer
Jan 31, 2012 01:59 PM
eg6d15
Aug 26, 2008 07:21 AM
wad5150
1G TL Problems & Fixes
Dec 28, 2007 01:09 AM
ceo22
1G TL (1996-1998)
May 25, 2004 10:41 AM
clforeversj
Sep 21, 2003 11:33 AM
