Remove and replace the doors.
Old Mar 1, 2020 | 11:16 AM
Milkdudcool1's Avatar
3rd Gear
Do anyone know how to remove and replace the doors. My driver door was hit and it will not close properly and i need to replace it.
Old Mar 1, 2020 | 07:12 PM
01acls's Avatar
Please post some pics of the damages? If the car frame is bent it would be a moot point to replace the door.
Old Mar 1, 2020 | 08:35 PM
3rd Gear
This is the damage the frame wasn't damaged just the door.
Old Mar 2, 2020 | 01:30 AM
hans471's Avatar
If it really bothers you and you just remove it:
Remove the inner door panel.
Disconnect all the wiring and fish it out through the entry point where it inters the door. (There will be a rubber boot that will need to come out also).
Remove the bolts holding the door hinge to the door. This has to be done with the door open and with some means of supporting the door....its heavy!.
Install the new door by reversing the process used to unbolt the original one. NOTE: Doors have to be carefully aligned to open and close properly. Be sure you understand how to perform that task. Some adjustment will be done at the hinge area while other adjustment will likely be needed at the striker plate where the latch engages.
Transfer the locking mechanism (the part where the key goes in the door) from the original door to the replacement door so your key will still work.
Fish the wiring back inside the replacement door and reconnect all the wiring. Replace door panel and associated handles, switches and trim.
OR.....remove the door panel, push out the dent as best as possible and live with it.
Old Mar 3, 2020 | 02:49 AM
01acls's Avatar
See the link below. The procedure is similar to your vehicle but your lock cylinder is much easier to remove.
https://acurazine.com/forums/2g-tl-p...cement-929421/
robocam
Oct 9, 2015 06:01 AM
normaspirated
Jan 5, 2012 10:35 AM
bahamajama
Oct 6, 2010 03:34 PM
cicacci2190
Jul 7, 2010 04:05 PM
rhizopod
Sep 3, 2002 08:02 AM
