Quick question regarding 2004 body changes
Old Feb 6, 2014 | 05:12 PM
tag4545's Avatar
I need a new fender for my 04 RL, I found one but it shows that it fits the 96 - 03, and the one for 04 has a different part number. I'm not aware of any body changes in 04, I was hoping someone knows if the older fender is compatible. Thank you.
Old Feb 26, 2014 | 10:27 PM
Beatindastreets's Avatar
9th Gear
Try a pick and pull junk yard or www.certifit.com. Maybe even ebay.. I have a 97 rl wanted to make look like the 2002 and they told me I had to change the hood fenders bumper lights even the radiator support idk if any of this helps but good luck
Old Feb 27, 2014 | 10:40 PM
Ken1997TL's Avatar
Fenders for '99 - '04 should be the same.
Old Mar 4, 2014 | 01:21 AM
9th Gear
Can u use any 2004 parts in an 97 rl I like the 04 speedometer n inside?
Old Mar 4, 2014 | 08:13 AM
MyNameIsEarl's Avatar
No, in 2004 the instrument cluster got an update that not only has different aesthetics than previous models, but it also, upon ignition, will cycle the gauges to their max readouts and down again.
The radio, and likely navigation system are different as well because they integrate voice command technology.
Old Mar 4, 2014 | 09:21 AM
Ken1997TL's Avatar
Yep, virtually everything electronic in the '04 RL is unique. You would have to swap out numerous modules and wiring harnesses. Much cheaper to just buy an '04.
Rdub81
ILX Photograph Gallery
Mar 17, 2016 03:02 PM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
datadr
Sep 12, 2015 09:12 PM
Redsand353
Sep 6, 2015 01:03 PM
Aug 30, 2015 02:39 PM
