Key not working sometimes-'97 RL
Old May 16, 2015 | 12:36 PM
cbrig's Avatar
Sometimes there is a green blinking light at the top of the speedometer and the key won't work. I will cut off, sometimes take the key out and do the 3-4 times, then the light cuts off and then the engine will turn over.
Anyone else experienced this?
Old Jun 23, 2015 | 01:38 PM
strato rl's Avatar
7th Gear
My 96 is doing this sometimes and I was told by a good mechanic that if your battery voltage is low it may not sense the key.Try a fresh battery of a high capacity-800cca.When I mean low voltage this is the voltage the battery has when the car is off.Should be around 12.5volts.As batteries age the voltage gets a little lower around 12.0.This doesn't seem like much but the Imobilizer circuit is very sensitive.Or a bad solder joint on the main relay.
acurajj
Sep 19, 2015 03:47 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
ahsm
Sep 9, 2015 08:35 AM
