Ignition Switch Sticking 02
Old Aug 24, 2012 | 04:03 PM
davethedyer's Avatar
Sometimes I can't get it to turn after the initial quarter turn to engage starter.
I tried spraying with Super Lube but no real difference.
Old Aug 25, 2012 | 09:46 PM
Has anyone had to replace their ignition switch??
Anyone...come on folks...
Old Aug 26, 2012 | 10:05 PM
kid spartan's Avatar
I'm not exactly sure what you're saying is the problem, but is this it:
you turn to ON and the dash lights come on fine
you turn it again to start and nothing happens? This is a common RL problem and it has to do with the security system being slow. If you slow down your turns from ACC to ON to start, it'll be fine.
If this is the problem and the key is actually sticking, then I have no idea.
Old Aug 27, 2012 | 01:31 PM
It won't turn all the way. Not electrical but mechanical. I have to push in and play with it a bit to get it to the start mode.
Old Aug 27, 2012 | 09:54 PM
av8r's Avatar
Couple thoughts..... Have you tried a second key? Sounds like a problem I once had with a reman key. Does moving the steering wheel have any affect?
Old Aug 28, 2012 | 10:05 AM
It seems to happen with either key. Haven'y tried the steering wheel but pushing the key forward sometimes helps.
Joe Avesyan
Sep 29, 2015 03:57 PM
malvothegreat
Sep 29, 2015 12:38 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
h22lude
Sep 27, 2015 06:22 PM
eastcoastguy
Sep 23, 2015 06:29 AM
