Help Urgent! Tail Lights Not Working
My tail lights went out today. I have brake lights, back up lights, and my high mount still works. When i press the keypad, the courtesy lights do not light up in back. The front lights work but the back lights do not. I need help urgently. I dont want to pay the dealer and im hoping someone else has had this problem.
Hi, Could you be a little more specific? interior or only taillights? the courtesy light is throwing me off. i would check your fuses "stop light fuse" also check your bulbs hey its simple enough sometimes overlooked. write back!
I probably should of used running lights, the little lights inside the head lights, and the ones you see light up when you press the keypad. What happened was i tried doing a fog light mod, so i can use my fogs only with the running lights. I like how it looks, but it went horribly wrong. Now i had tail lights after i did this, but they went out yesterday. I chekced the bulbs and everything seems to be good. Im going to the dealer, and i can only hope this wont run over 1k. Im going to have to swallow my pride and look like an idiot at the dealer and show them mine and my friends handy work. I will NEVER try anything like this again.
handsom-hustla
11-13-2015 05:04 PM
wusty23jd
09-24-2015 11:41 AM
