EGR valve install question???
Old Jun 8, 2008 | 07:55 AM
DubRL's Avatar
I have a 98 RL with 97k miles. The check engine light is coming on every 50 miles or so for EGR valve insuffient input or something like that. I will clear the code and it will just come back on. So I bought another one and installed it but it is doing the same thing. Is there anything special you need to do when installing besides bolting it on, gasket, and plugging it in?? Thank you.
Old Jun 8, 2008 | 08:11 PM
rickb20us's Avatar
more work needed
Go to this post ---> https://acurazine.com/forums/showthread.php?t=5679
and look at thread #'s 7 & 8.
Old Jun 9, 2008 | 04:10 PM
DubRL's Avatar
thank you very much. looks like i have a little bit of a job ahead of me.
Old Jun 9, 2008 | 07:09 PM
SdotCamp's Avatar
8th Gear
It is a pain in the ass actually. Depending on how clogged the EGR port is it could take a few hours.
Old Aug 1, 2008 | 03:45 PM
timberland73's Avatar
99 TLS6 08 TL
My mom has a 2000 RL that needs a new EGR valve. Dealer wants upward towards $700 to replace. What will happen in the long run if this isn't fixed asap?
Old Aug 1, 2008 | 03:54 PM
rickb20us's Avatar
check my link above
Did you read the information at the post above? I suspect she doesn't need a new valve, but that it just needs to be cleaned well. Full instructions are included at the link I referenced.
Old Aug 1, 2008 | 11:58 PM
Big Green Acura's Avatar
I replaced mine myself. It didn't help at all. It was a 15 min install though. It needed to have the system cleaned and a port was clogged resulting in low pressure. It's fine now. The dealership charged about $50 to fix.
Old Aug 2, 2008 | 01:16 PM
99 TLS6 08 TL
The link you referenced doesn't work.
Old Aug 3, 2008 | 01:11 AM
Jimmay's Avatar
http://www.nsxprime.com/FAQ/Reference/tsb/98-031.htm
check that out i do believe your covered under an extended emissions warranty. Take it to Acura and let them fix it. It should be free.
Old Aug 3, 2008 | 11:26 PM
MasterD86's Avatar
i think its only 96 and 97. i wish it was for 98s because i have one and the same problem. i got a new egr valve which didn't fix it and the small pipe in the back was not clogged at all. my next try will be seafoam.
ibGTV
Sep 28, 2015 03:40 AM
Skirmich
Sep 15, 2015 06:41 PM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
