Did the 98 RL base come pre wired for navi
Is the 98 RL base pre wired for Navigation even if it was not included? I have the center console with navi from a 98 but my RL is the base and wonder if it is even wroth trying to switch it out. I wonder if it is basically plug and play or if it will require extensive modifications. Any thoughts? Thanks!
I don't know much about the 1st Generation RL's but I can say with confidence that it will require quite a bit of modifications; it won't be a simple plug and play.
If you need a navigation system, you're much better off just going with a portable unit; they are much more updated compared to the '98 system which is now 10 years old...
You could try to do a NAV setup using a new in dash Alpine, Eclipse, Pioneer, or Kenwood unit. Any decent sound shop should be able to do that for you. It would look way cleaner than a portable unit held on by a suction cup.
It is almost impossible to convert a non-navi RL to navi since you have to run hundreds of wires and configure them. I would strongly recommend to put a decent aftermarket 2-din in-dash navigation system, preferably Pioneer.
Did it to my 97 RL non/navi. Upgraded to 2002 factory navi. If you purchase the parts for the factory unit make sure you get atleast part of the wiring harness. Just requires a little extra effort
I have an idea....buy a tom tom.....cheaper and better in the long run because it only costs around 90 dollars to upgrade the maps...verses over 120 for a new dvd...plus the cost of the whole in dash set up. Just my two cents
navtool.com
31
11-16-2015 08:30 PM
SUPRMN84
10-07-2015 09:46 PM
