Car start/stay running problem
Hello everyone,
My car has a strange issue. I first thought it was the starter but then read through various posts and thought it might be the main relay. Now I am just confused and haven't done anything yet.
Some days I will go to my car and put the key in the ignition to turn the car on. I turn all the way, nothing. No crank, no start. I'll turn it a couple more times and then suddenly it will start. This sounded like a main relay but I left it be. Then one day while driving, my car stalls and all lights come on the dash. I was able to immediately restart the car. The CEL ended up being for cylinder misfire (there were 3-4 codes, all for some cylinder misfire). I took it to the mechanic, he couldn't find anything wrong. We reset the light, drove like normal. Went on for a couple months of only slightly using the car and it happened again with the same issue.
Now I was thinking ok it has to be main relay. I pulled apart my main relay and the solder joints look fine. I put the same main relay in today and put my hand on it when I had the first condition where it would have no crank no start and the relay does click and I believe I heard the fuel pump in the back as well. So now I'm confused. Doesn't seem like main relay anymore to me.
Any thoughts?
Any thoughts?
3RLs4C
I have NO crank, no start issue I am fighting now. With my history with these cars here is what I can tell you. Your issue sounds like a connection issue. The main relay is more part of the starting process and then is monitored by the computer. The lights on the dash lighting up and misfire cofes lead me towards a computer issues, ground issue(Main ground in engine bay), check harness and connectors.
make sure all the connectors are clean and check for oil and other fluids.
I don't really work on cars much although I really want to. Do you have any pointers on the connections I should take a peek at? Most likely we will just get rid of the car since someone with no electrical knowledge would probably not be able to figure this out, but i still want to take a look.
3RLs4C
Thank you. I drove today and it stalled on me again.
Had a similar issue, it was the 3 inch hose in the tank was split!!
I think it is 2 separate issues. The crank issue I think is the starter. As the starter ages, dead spots will form. Mine has a few. As for the stall, sounds like the engine is either losing ignition or fuel. Figure out which one it is and good luck. By the sounds of it, it will be fun to troubleshoot...
I'm not sure if it is the starter for the first issue since it is 0 crank.
Starters do that when they are near death. They sometimes crank intermittently. Does it sound like a piece of metal clunks like the engine is seized when it doesn't start? If so, then its usually the starter is nearing the end. Try to get the Autel AP200. Its a very good scan tool for only 50-70 bucks, and it gives one manufacturer for free. Just drive around and log data. Log the engine data and see what happens when the engine dies. That'll give an indication on what is going wrong. Maybe its losing crank signal or as the others have mentioned, fuel pressure drops and kills the engine. Plus, the codes that are read will give an indication to what is going on if there any stored.
change the main relay don't mess around with it, is the starter may be going bad too, change the fuel pump and the intake air temp sensor behind the intake manifold 19mm socket change the water temp sensor too (not the gage sensor) check the map sensor plastic connecter and all the vaccum hoses i would change the map sensor plastic connector then recheck
I can log the data but the engine dies so randomly that it wouldn't happen for weeks and then one day it'll happen. Thanks for the suggestion though!
Check a few simple things. Make sure negative battery connection is extra snug. Check all the fuses for any breaks. Check remote battery and make aure its the right key. Check all hoses for fitment ,cracks,leaks or disconnects. You can also get a free odb scan at the local parts store...simple free and cheap search, to find the problem.
