ABS codes 97 and 98 meaning?
Hi all,
I got these codes by shorting the blue 2 pin connector under the glovebox and then reading the flashes from the dashboard after turning the key to the on position. Any help with their meaning would be appreciated.
If I recall I had the 98 code which was ecu mismatch error which was an odd one. My code scanners couldnt erase it but I found a video on youttube by Advanced Level Auto labled Acura Honda VSA ABS Lights on DTC 98-1 which showed me how to get rid of it since scantools couldnt clear it.
