98 RL CD Changer
98 RL CD Changer
I've got a 98 3.5RL and the CD Changer has failed. Up front I get a T-00 fail code that the dealer says indicates a bad changer. The disks cycle in and out of the box but don't show tracks or play. How do I remove the old changer? I can't see any way to access the unit from the trunk. Do you release the entire unit by bolts under the car?
Thanks for any help.
I guess I don't see how the unit is accessed in it's housing. It has a plastic trim piece around the top and the rest is covered in trunk liner. The top trim piece is firmly fixed to the housing. How do I remove the housing to get at the CD Changer?
Sorry, I don't have a digi cam...the housing is held down by poppers. Just pry it off...if you feel around the housing, it doesn't actually wrap all the way back. There ae 4 metal poppers, 3 in front and one of the left side (towards the back of the trunk). If you REALLY need help after this I'll see what I can do about a camera, but try pulling on it first
Doug
Doug
Guys, I feel dumb as a post. I used a screwdriver to pry gently under the housing and BINGO, off it came. Thanks for all the help and sugestions. Now, does anyone know where to get a replacement changer that works with Nav?
Chris.Su
Aug 13, 2002 07:09 PM
ChrisK_RENAMED
Mar 15, 2001 04:05 AM
