96 RL Speaker Install Help
I've done some searching, but didn't find much on the first gen section or here.
I have a 96 RL and want to replace the 6x9's in the rear deck and the 6 1/2 in the front doors. The ones I'm concerned about are the front door speakers.
In the first gen RLs there is a grill that looks to be removeable. If this is the case, how do I get it off? I've tried to pull and look around it, but am a little worried about doing permanent damage.
My main concern with the front speakers lies with the door paneling. I would hate if it didn't seal back up as tightly and the inside got louder or the paneling creaked when the door opened or closed.
If you guys know a good source to get FREE guides for speaker installs let me know. Thanks!
Update: I got the rear grills off just fine. The grill popped off with just my fingers, but the front grill is still a mystery. Anyone have info? Should I just pull harder?
First: Welcome to AZ!
I have to move this thread to the 1G RL section. There are some regulars there who may be able to help with this question.
Originally Posted by Big Green Acura
Don't do it! Unless you find the correct Ohm rated speakers don't! In my car there is both 1 and 3 ohm speakers which are hard to find! Bose systems are extremely hard to redo.
Originally Posted by GSARL
Those door grills dont come off you have to take off the door panels
The rear deck is extremely easy to get to.
Though then there is the issue of the Bose system. Do all RL's have Bose stereos? I can't find marks anywhere. I looked again today and can't seem to find any indication that it is a Bose system.
Ive taken them off myself its pretty easy,when you put them back on put the window all the way down and start at the top snap in the top first then just hit the panel with your fist to snap back in the sides and bottom.As far as being loose or rattling as long as there in correctly you should'nt have any problem. I think most RLs have a bose system anyway whats the difference if your changing them.
You can get the speaker harnesses from Best Buy. A pair is about $12. They clip to the factory system and have the + & - wires to clip to the speaker. Good Luck.
How easy is it to get them back on? My main concern is that when they are removed they won't be reinstalled properly and will either rattle, creak, squeak, or just be generally loose.
Originally Posted by 96AcRite
The 96 came with two sound options; the basic was an Alpine system and the Premium was the Bose. If you have the Bose you might have to bypass the amp. I had the Alpine in mine and I just took the factory speakers out and dropped the Infinity's in there.
Is it worth $40 to have Best Buy install the Infinitis in the front? Also, should I do any dynamatting?
I'd like the doors to have a more solid "new car" close. Really quiet and tight. The road noise so far is much better than my other car, but I'd like to seal things up and deaden anything I can.
Front-Speaker Install
Sounds like what I want to do. I'm really worried about messing up the front door panels. I am planning on replacing the front door speakers and rear deck 6x9s. I think I must have the Alpine system. I can't find a "Bose" bit anywhere, but since I haven't removed anything yet I can't say for sure.
Here are some pics from my install last week.
Pegon95
09-15-2015 01:54 PM
alan_rich
09-07-2015 11:08 PM
