2002 Acura RL ABS/VSA light code 94-1
Old Oct 29, 2019 | 06:57 PM
coreyt30's Avatar
3rd Gear
Hello everyone, I am new to posting so please ignore my ignorance. I have had they ABS and VSA light on. I have a Maxicheck pro scanner and it shows a 94-1 (sub throttle sensor failure). I have not been able to clear the code but have been able to clear other codes without an issue. I used the live data and found that the LF wheel is showing 143.54 mph so I figured it was a bad wheel sensor and I replaced. Still has code and will not clear, I reset ECU but still nothing. Any suggestions would be great.
Old Oct 30, 2019 | 05:50 PM
Babafats's Avatar
Hi
Code 94 on the VSA is the TCScontrol valve sensor on the air intake trunk
Are you sure its 94- 1 on the code as i have the manual and al the VSA codes are 2 digit
Old Oct 30, 2019 | 07:34 PM
coreyt30's Avatar
3rd Gear
Thank you so much!! I originally thought why would that have anything to do with it considering the car ran fine, no stalling or rough running. I figured out that I didn't put the sensor on correctly last year after I did work on the car. I think the 94-1 might have something to do with the scanner I am using. Unfortunately now I have another error, 84-1 but probably should just by 84, steering sensor error.
Old Oct 30, 2019 | 09:42 PM
Babafats's Avatar
They r really sensitive I dropped mine when i removed it to fix the gasket n when I put it back it gave the same error I got one from the scrapyard I'll see if it gets rid of the code
Old Oct 31, 2019 | 05:52 PM
coreyt30's Avatar
3rd Gear
I was able to get VSA 94 resolved but now I have VSA 84, steering sensor error. I tried using my scanner to do a neutral reset but it's not registering the steering wheel moving.
jcniest5
1/2G MDX (2001-2013)
Sep 24, 2017 06:38 PM
clencalada
1G TSX Problems & Fixes
May 16, 2015 07:32 AM
jmindler
1G RL (1996-2004)
Mar 19, 2013 07:26 PM
dmbfan36_23
Dec 8, 2012 10:28 AM
DimaB
May 4, 2011 05:26 PM
