VSA code 64-1 sensor supply voltage malfunction
Old May 15, 2015 | 09:49 AM
clencalada's Avatar
i have the triangle with the vsa light on, no abs light. i scanned it with a autoparts scanner. i got 64-1 sensor supply voltage malfunction. What can this be? my battery is 6 months old and i checked the voltage on it before and after i tricked charged it and its good. ive tried to clear the error with jumping pin 4 and 9, and vsa neutral position recalibration but it doesnt work.
Old May 15, 2015 | 04:21 PM
TexasHonda's Avatar
I checked 04-07 TSX shop manual and did not find a code 64. Possible transciption error or faulty scanner result.
What year is your TSX?
Did you try to manually extract SRS codes?
DIY: SRS Codes and reading them. - Club RSX Message Board
good luck
Old May 15, 2015 | 06:02 PM
clencalada's Avatar
thank you, its a 2008 5 speed auto, with 106k miles.
i havent tried to extract srs codes, ill try that. thanks
Old May 16, 2015 | 07:32 AM
TexasHonda's Avatar
My manual does not cover 08 year, so possible that code 64 does apply to your vehicle.
Check ebay for options on a shop manual for your vehicle to get diagnostics for your code, if you're successful w/ manual method.
good luck
Jamus22
Jun 11, 2023 10:08 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
