1st gen RL question!!
Old Jan 18, 2008 | 09:44 AM
jawbreaker06's Avatar
8th Gear
I live in the chicago area & I'm looking to get my intake manifold cleaned out.
When I went to an Acura certified mechanic he told me it would cost over $1300.00!!!!
I would do it but it's like 5 Degrees right now.
Please help!!!
Old Jan 18, 2008 | 03:35 PM
Ken1997TL's Avatar
Find a different mechanic
Anyone who can work on an Acura Legend can do this, its not hard at all.
Old Jan 18, 2008 | 04:50 PM
Megatron's Avatar
Please help!!!
I had it done at an Acura dealer for $300. That's without diagnosis or anything. I got a Check Engine Light... read the code myself and then took it in and told them to just clean the intake manifold without diagnosis.
They must be wanting to do other stuff for $1300!!!
Old Jan 20, 2008 | 12:51 AM
BelowRadar's Avatar
dealers
I just don't get dealers. I was curious the other day, went past an Acura dealer to see how much they would charge to aim my headlights since i can't find a flat space around here, and they wanted 50 bucks ! ! !
Old Jan 24, 2008 | 05:04 PM
antoinewilson22's Avatar
did i get a good deal or a lemon?
just bought a 2000 rl for 6000.00. a few dayz later my abs,checkengine,and vsa light came on. car has 150000 miles on it. was this a good deal? should i have it serviced at acura or a local ase certified repairshop?
Old Jan 24, 2008 | 05:30 PM
97_RLer's Avatar
Ultimate DIYer
It seems like the previous owner had disconnect battery to erase those error codes right before sell it to you. Anyway your deal is not bad considering the price with mileage. The private party price for yours is around $6,700 with clean condition.
I don't know much about the condition of your car but if the car has physically good shape in and out and no other major electrical or mechanical problem except those you listed.
Your problems are not major but common problems for 1st gen RL. It probably caused by a bad ABS sensor(s) usually at the rear sensor. You'd better read the error codes first at any auto part store for free, then, start to troubleshoot it.
Old Jan 24, 2008 | 07:36 PM
Big Green Acura's Avatar
97_RLer how did you get your speedometer to look like that?
Old Jan 25, 2008 | 03:46 PM
Ken1997TL's Avatar
I assume he got the 2004 RL gauge cluster or simply has a nice picture of one
Old Jan 25, 2008 | 10:45 PM
I was wondering since I have been looking for a 04 cluster for a while with no results. How much would it cost from Acura? Would they even do it since they would suspect foul play on mileage?
Old Jan 26, 2008 | 01:42 AM
97_RLer's Avatar
Ultimate DIYer
I will unveil the secret of my gauge cluster soon. The gauge cluster looks much better than 04 RL's. You got to see the close-up photos. It is actually 10 of 3-LED bulbs. You can't imagine how bright they are!
I did a lot of tiny modifications on my 97 RL with the cheapest way but with the best qualities. I will write up some DIY's whenever I have time.
Old Jan 26, 2008 | 10:35 PM
I don't think the 97 and 99+ use the same cluster. I am looking at getting a spare to try to jazz up a little bit.
Old Jan 27, 2008 | 08:11 PM
BelowRadar's Avatar
dash cluster
97 RLer.... I thought for sure that was an 04, but would be interested in knowing exactly how you got it to look like that. I'm having the hardest time finding an 04 cluster and 04 navi system with dash set-up.
Old Jan 28, 2008 | 08:10 AM
8th Gear
Question 96 Rl non navi conversion
I have a 1996 RL non navi & I am wondering what navi head units might fit with little to no modifications?
Old Jan 28, 2008 | 01:48 PM
niiotoo's Avatar
I have a 2002 RL with 20" wheels. My tires rub during turns and mid size bumps in the road. I've looked into getting stiffer suspension (strut tower bar) and an aftermarket rear sway bar. Will a type s TL or RSX suspension kit fit my 2002 RL? What are my options?
Old Jan 29, 2008 | 08:22 AM
chitownRLer's Avatar
Please help!!!
Jawbreaker, call this place and find out if they'll do it. My coworkers recommended this place I've heard nothing but good things. Fortunately, I've not had anything go wrong in a while so I've not used it personally. check it out and lemme know how it works out. There's also a place in Skokie, that i've used before but can't remember the name right now. I'll post it later if i remember
http://www.importservicecenterinc.com/homepage.html
Old Jan 29, 2008 | 08:23 AM
Please help!!!
ok, just found it....try this place as well. The guys name is Phet at G&G automotive.
http://chicago.citysearch.com/review/3484480
Old Jan 29, 2008 | 04:32 PM
super-rl's Avatar
just go to in auto parts store get some coil over install it your self it's will raise the car about 1" or 2", work fine for me 20" 8.5 with 40 offset no problem at all
Old Jan 30, 2008 | 02:27 AM
97_RLer's Avatar
Ultimate DIYer
I posted a new thread of the LED instrument cluster. Here's the link.
https://acurazine.com/forums/showthr...0045#post60045
Old Jan 30, 2008 | 01:33 PM
8th Gear
Convert to navi?
[QUOTE=97_RLer]I will unveil the secret of my gauge cluster soon. The gauge cluster looks much better than 04 RL's. You got to see the close-up photos. It is actually 10 of 3-LED bulbs. You can't imagine how bright they are!
I did a lot of tiny modifications on my 97 RL with the cheapest way but with the best qualities. I will write up some DIY's whenever I have time.[/QUOTE
I have a 96 3.5 RL & want to install Gps.
Should I go for an aftermarket one or swap one out from a newer model?
Old Jan 30, 2008 | 01:37 PM
[QUOTE=jawbreaker06]
yikes that sounds messy, costly and time consuming! just go to tigerdirect.com and buy a navigon 2100 for $149.00
Old Jan 30, 2008 | 01:45 PM
8th Gear
Has anyone tried putting a game console in their Rl?
I have a 360 I want to hook up to my Rl...any ideas?
Acura604
Oct 7, 2015 06:08 PM
datadr
Sep 12, 2015 09:12 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
Redsand353
Sep 6, 2015 01:03 PM
obert
Sep 3, 2015 08:40 PM
