1997 Acura 3.5 rl ignition switch eplacement
Old Dec 30, 2016 | 07:35 PM
Switch540's Avatar
3rd Gear
How do you remove ignition switch
Old Dec 31, 2016 | 09:02 AM
01acls's Avatar
Remove the steering column covers. You will see bolt heads that's been sheered off due to anti theft breakaway bolts being used on the lock cylinder. You need to some how create traction so you can unscrew the headless bolt by either cutting a slot on top or chiseling the edge to get it to start turning and unscrew the bolts that way.
If you're trying to replace the ignition switch pig tail, then you might be able to remove that part without removing the lock assembly.
Old Jan 1, 2017 | 09:09 AM
Switch540's Avatar
3rd Gear
i was wondering because i have not found my service manual yet
and it is not mounted on the column but on the dash,
happy new year!
Old Jan 1, 2017 | 09:45 AM
01acls's Avatar
The lower panel just snaps in.
A4orce84
Jan 1, 2017 08:06 AM
redline_TL
New Member Introductions
Nov 13, 2016 02:25 PM
FR8TRAIN
1G TL Problems & Fixes
Oct 19, 2016 03:02 PM
Allison Cronin
1G TSX Problems & Fixes
Oct 17, 2016 09:55 AM
Rami Jas
Oct 8, 2016 08:30 PM
