02 RL complete swap into an 00
Skeet Skeet Skeet
This might be a long shot on in this forum but anyways. I getting ready to put a complete swap from and 02 into my 00 does anyone know if i can use my 00 ECU or ill have to use the one from the 02? also is there any difference in the wiring or should be just direct plug and play...thanks
Received 2,329 Likes
Why are you doing a complete swap? The hardware is almost identical..
The ECU MIGHT be different but the main difference is a different silencer in the exhaust that gives you better torque and HP.
Otherwise the suspension is the biggest and most noticeable difference between the two years.
complete swap as in engine or something else.
If your just dropping in an engine there shouldnt be that much of a problem. If any pars differ just swap em for your old onto the new.
If your trying to do the swap for a couple of extra horses you might have to swp wiring harnesses which would be a pain.
On a side note do you have a 02 your parting out or something?
Skeet Skeet Skeet
xsilverhawkx
09-28-2015 06:51 PM
