CV Axles
CV Axles
Hey guys looking for some advice here. My 08 RDX has developed a vibration when accelerating between about 40-65mph. Took it by the dealership and they told me that both front CV axles need to be replaced along with the half shaft. The problem is due to the nation wide parts shortage the OEM parts are backordered indefinitely. Has anyone had good luck with aftermarket parts or does anyone know a place that has the oem ones in stock? Ive tried like 3 different places online and none of them are able to get the oem parts either.
I’ve also read the 2nd generation MDX has problems with impeller/drive shaft U Joints causing vibrations . Test : remove shaft and test drive .Not so sure we have that with our RDXs .
To the OP , I would definitely get another opinion from someone who delves into these kind of problems. Dealers have several grades of mechanics.. which one did you get ?
Sorry old skater dude, but yeah, oem is best
https://acura.oempartsonline.com/search?search_str=CV Joint Kit&ptid=11621
sprintership
3G RDX Performance Parts & Modifications
03-21-2020 02:46 PM
