CV Axles
Hey guys looking for some advice here. My 08 RDX has developed a vibration when accelerating between about 40-65mph. Took it by the dealership and they told me that both front CV axles need to be replaced along with the half shaft. The problem is due to the nation wide parts shortage the OEM parts are backordered indefinitely. Has anyone had good luck with aftermarket parts or does anyone know a place that has the oem ones in stock? Ive tried like 3 different places online and none of them are able to get the oem parts either.
Nobody has any suggestions?
Originally Posted by ImagioX1
(Post 16871303)
Originally Posted by DaIll1
(Post 16871605)
Unless the axels are bent, you can probably replace the CV joints alone, which should be more accessible.
I’ve also read the 2nd generation MDX has problems with impeller/drive shaft U Joints causing vibrations . Test : remove shaft and test drive .Not so sure we have that with our RDXs . To the OP , I would definitely get another opinion from someone who delves into these kind of problems. Dealers have several grades of mechanics.. which one did you get ? |
Originally Posted by Chopperpilot
(Post 16871630)
oem axels /axles.
https://acura.oempartsonline.com/search?search_str=CV Joint Kit&ptid=11621 |
