Tire issue - Can I replace just one?!
Old Apr 21, 2009 | 10:14 AM
Teledatageek's Avatar
I have had a slow leak in one of my tires. Auto place just inspected the vehicle and checked out the leak. Found a screw in the tire and said the tire had to be replaced.
I am closing in on 21K miles - I would the tires have some life left to them but can you just change one tire with an AWD vehicle? I thought you couldn't..
Can someone provide some insight.
Thx.
Old Apr 21, 2009 | 10:50 AM
number84's Avatar
i think in general you should be replacing tires in pairs at the very least. 21K miles is still quite a bit tread use for the other 3.
Old Apr 21, 2009 | 09:22 PM
Rexorg's Avatar
Thx.
If the screw wasn't in the sidewall it can be repaired. Be sure to get a plug and a patch if it can. Otherwise, you have to replace both tires.
Old Apr 22, 2009 | 05:54 AM
Yeah, it's in the sidewall and can't be repaired unfortunately.
I did some reading on Tirerack and they recommend all tires have the same tread depth with AWD vehicles and provide a shaving service. The tires have 5/32 left - the Tirerack folks indicate they consider end of life to be 4/32. They said shaving a new tire makes sense when you have 7/32 or more left on the other tires.
So - I think I'm going to replace all of them at this point unless the Tirerack advice is all wet....
Old Apr 22, 2009 | 10:45 AM
MMike1981's Avatar
big shot.
happened to me over the winter...i had 15k on the tire...replaced just one, the rest were still in good shape, we rotated to closely match treads....no problems put on 5k after replacing 1 tire
Old Apr 22, 2009 | 10:58 AM
Rexorg's Avatar
You might want to check at your Acura dealer. They often have take off tires from wheel/rim upgrades. Doesn't hurt to give them a call.
Old Apr 22, 2009 | 04:33 PM
I took your advice and called my dealer - they didn't have any used ones but thought there wouldn't be an issue with just getting a new one given is on the rear. They said I might notice some vibration/shimmy when it got rotated to the front.
So, I don't know....
Old Apr 23, 2009 | 08:19 AM
MMike1981's Avatar
big shot.
well, what ur dealer should have said was put the new one on and rotate all tires to match, the new tire should go in the front when you get it replaced. you wont have a problem doing just one tire.
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
cammy5
Sep 4, 2015 11:26 PM
asahrts
Sep 4, 2015 05:55 PM
bailey24
Aug 31, 2015 05:38 PM
