Sunlight Sensor Problem?
Old Jan 14, 2007 | 09:47 PM
kirkacanada's Avatar
5th Gear
When I turn on my headlights, the nav display automatically goes into night mode (darker screen/colours). However, I thought in daylight, the sunlight sensor would set the nav display to daylight mode (for easier viewing) - even when the headlights are on.
Have I misunderstood this feature on the nav display? Or could this be a problem with the sunlight sensor?
Thanks!
Old Jan 15, 2007 | 01:28 AM
sgi's Avatar
sgi
7th Gear
I get the same behavior, not sure if this is normal or not.
Old Jan 15, 2007 | 06:01 AM
dwest1023's Avatar
Thanks!
Normal. you can turn your dimmer switch on high. and the navi will turn bright.
Old Jan 15, 2007 | 12:26 PM
5th Gear
Thanks for the reply.
Yes - the brightness can be turned all the way up, but then the system does not switch to NIGHT mode when the headlights are on (and it's dark outside).
The user's manual for the navigation system contains a section on the logic for "Switching Display Mode" under System Setup. It clearly states "If the sunlight sensor detects daylight and the headlights are turned on, the navi automatically overrides (cancels) the NIGHT display and displays the DAY display mode".
I was wondering if anyone can confirm this logic actually works??
Appreciated.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
NSolace
Sep 3, 2015 08:02 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
