Strange sound coming from steering column
I also have this sound, but it manifests differently. Once i turn the key to ON, without starting the car, I get that sound as if something is moving into position or energizing. It only lasts about 3-4 seconds but happens everytime. I have noticed it happen intermittently with a very low frequency during other occasions, sometimes while driving or just sitting idle, but that is relatively rare/hard to reproduce.
sounds like the air mix motor assembly.
Motor on door for vent under driver seat could be bound up and that is the popping.
Try selecting all air to go to the floor, then to the dash or windshield. Feel with your hand to see if airflow changes.
I had the same thing on my 08 RDX and there was a TSB to re-grease the mix door for HVAC. It helped with the noise at start ups: https://www.motor.com/magazinepdfs/042012_13.pdf
Here is a link to the Thread for a fix: https://acurazine.com/forums/1g-rdx-...-noise-862172/
I Google searched under "acura rdx blend door actuator tsb" if the above link doesn't work.
Did you figure out if it was the HVAC mix door?
I am having the same problem. Started a year ago when I would have the noise intermittently. Now whenever the AC is on for >30 minutes I would get this noise continuously. I was wondering if there is a good/reasonably priced fix for it, if not I'm thinking of trading in the car for something else but really avoiding to!
Sure sounds like the air mix motor to me. My 2008 was making that noise and I put in a new motor (part # 79160-STK-A41 for the 2008, $41 shipped from Delray Acura) back in December. It's not too difficult to swap out - just a little tight under the steering column/dash area.
I tried greasing the motor as shown in the thread(s) mentioned earlier in this thread. That helped for a couple of months. When the noise came back I just popped in a new motor so I could be done with it.
TSX69
3G RLX Audio, Bluetooth, Electronics & Navigation
94
09-17-2018 07:45 PM
lowther420
ILX Audio, Bluetooth, Electronics & Navigation
11-07-2016 03:31 PM
