Sound under steering column
Old Aug 4, 2016 | 09:19 AM
solotallboy's Avatar
HI All,
I'm the new owner of a 2010 TL Tech package. I notice when i'm eirther starting the car or shutting off the ignition, I hear a brief 'grinding' sound under the steering column. Is this normal? or is that something that should be moving that's not moving?
Any feedback will be helpful.
Old Aug 4, 2016 | 09:52 AM
mossman77's Avatar
Is your telescopic steering wheel working properly? I'm not exactly sure what the mechanics are, but maybe it's trying to move but can't.
Old Aug 4, 2016 | 10:07 AM
is the telescope automatic? I don't see it moving in and out. Hmmm
Old Aug 4, 2016 | 10:57 AM
mossman77's Avatar
I don't have the tech package, but I believe it can be set to manual or automatic. Check for a switch on the left side of the steering column. If there is not switch, then I don't know what to tell you. I have to imagine there is some way to disable it. When enabled, it should retract inward and upward when you shut off the ignition, and outward and down to your memory position when turning the ignition on.
Old Aug 4, 2016 | 11:04 AM
Interesting. I will have to investigate later this afternoon. Thanks for pointing me in this direction.
Old Aug 5, 2016 | 01:41 PM
So i looked on both sides of the steering column but do not see a switch. Is there a part in the steering column that's not working? Just a little bothersome to hear this sound before and after a drive.
TSX69
3G RLX Audio, Bluetooth, Electronics & Navigation
94
Sep 17, 2018 07:45 PM
Jinkazetsukai
Aug 5, 2016 11:35 PM
JUSPEN80
Jul 26, 2016 08:21 PM
FoxRL
1G RDX Problems & Fixes
May 8, 2016 02:22 PM
JoeB1k
1/2G MDX (2001-2013)
Mar 23, 2016 08:45 AM
