steering/trans vibration @25-30mph
Old Jan 17, 2014 | 10:34 AM
Jkay33's Avatar
6th Gear
Hi, Has anyone had to resolve an issue with vibrations felt through the steering wheel when driving consistently at 25-30 mph?
To reproduce, i put the Car in D, get up to speed at about 27mph, and sit at 27mph w/ light throttle, just enough to maintain the speed. The rpms then fall slightly, seem to settle at around 1100 or so to maintain 27mph. once the rpms settle, their is a pronounced vibration that can be felt up the steering column - it even makes the keys in the ignition shake, and you can feel the vibrations in the drivers seat and steering wheel.
It almost feels like on a manual trans, when in too low a gear and the engine is bogging.
2011 Rdx FWD, 37k miles, original owner.
Thanks.
Old Jan 22, 2014 | 09:50 AM
Jkay33's Avatar
6th Gear
Bump - anyone have this issue? any ideas?
Old Sep 7, 2014 | 10:44 PM
quincy011's Avatar
4th Gear
Hi, my '08 does the same thing. I've taken it in repeatedly, and got the 'can't duplicate' response so many times. I finally took one of the techs on a test drive where it did it for him. Their fix was a transmission 'service' which included fresh transmission fluid (I think it was about $250), and it solved the problem for about a year. It's come back now, so I have to pop for the service again.
Old Sep 8, 2014 | 11:25 PM
DRR98's Avatar
D/side drive shaft!
Old Sep 9, 2014 | 01:14 PM
quincy011's Avatar
4th Gear
DRR98, did you have it on your RDX, and find that the drive shaft was the problem? My extended warranty ends in less than a year and I'm getting nervous about these problems, which they 'can't duplicate.' Once the warranty ends I'm sure that, all of a sudden, the problem will be duplicated, and a paid solution come available!
Old Sep 29, 2014 | 03:12 PM
edomrose's Avatar
Had a similar problem with my '08 Rdx at around 70k miles. Needed a drive shaft replaced $720 at dealer!
Old Sep 29, 2014 | 11:50 PM
dcmodels's Avatar
Do you know what was the problem? U-joint worn, drive shaft bent/ damaged, other? I don't understand why the drive-shaft itself would require replacement, unless it was damaged. U-joints do wear, but they can be replaced individually.
Old Oct 9, 2014 | 03:38 PM
littleblazer's Avatar
I replaced both L & R drive shaft OEM 150.00 each.
Old Nov 28, 2014 | 10:18 AM
gaTorSXtasy's Avatar
Did this get rid of the problem?
Old Dec 6, 2014 | 12:45 PM
Changing it solve the problem
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
