pulled codes
Old May 2, 2016 | 02:25 PM
kooch20's Avatar
pulled codes
B1275
B1276???? any ideas i did a search??? nothing.
much thanks
Old May 2, 2016 | 02:45 PM
^those are not typical OBDII scanner codes.
OBDII codes often start with a P.
please re-scan and give the codes that start with a P.
or please give symptoms of problem which made you scan it.
Old May 2, 2016 | 05:53 PM
kooch20's Avatar
I did the old paper clip in the OBD 9 and 4 to pull the codes.
As for symptoms it was only the check engine and check awd light
I am 100% that it was a B not a P
I'll take some pics just to show
Just for clarity it was
B1275
B1276
scs service
TPMS DTC 11 13 15 17
PA10
Old May 2, 2016 | 06:50 PM
kooch20's Avatar
Maybe I'm not reading this right?
Old May 3, 2016 | 10:54 AM
ahhh!
DTC codes are different than an OBDII plug reader codes!
DTC are manufacture SPECIFIC! which means you would need a Honda book that explains all the codes.....
these are DIFFERENT than the auto generic P0xxx codes..
Old May 3, 2016 | 10:58 AM
it would be easier for you to just to go to autozone and get the OBDII generic P0xxx codes that TELL you exactly what's going on
I keep trying to google "DTC B codes" but its super hard to decipher
Old May 3, 2016 | 03:52 PM
DRR98's Avatar
On our vert its for the bcm- body control module...
Old May 3, 2016 | 08:14 PM
kooch20's Avatar
Ya not much info out on this. I'll get the mechanic to take a look at some point. As for now no lights on the dash.
Old May 3, 2016 | 08:15 PM
kooch20's Avatar
BCM ehh
Old May 10, 2016 | 04:20 PM
kooch20's Avatar
still no idea what these codes are ....
Old May 25, 2016 | 09:02 PM
greg1c's Avatar
Here is what I found
B1256
Air Temperature External Sensor Circuit Short To Battery
B1257
Old May 25, 2016 | 09:04 PM
greg1c's Avatar
B1275
Servo Motor Potentiometer Vent Circuit Short To Ground
B1276
Servo Motor Potentiometer Foot Circuit Failure
Old May 26, 2016 | 08:38 AM
kooch20's Avatar
hey thanks for that info
ya my light keeps popping on and off ill have to bring it in soon.
Old May 26, 2016 | 09:14 AM
like.....any auto store can read the check engine light for you and give the appropriate P-codes.
i think you are doing it the hard way, by checking the codes via special key sequence....which gives you specific manufacture codes instead of the codes that are generally outputted by the OBDII system...
like, you are creating a problem when there wasnt one.
after work today, drop by autozone and ask if some one can check the "check engine light" on your dash
Old May 26, 2016 | 11:23 AM
kooch20's Avatar
not sure of a walk in shop that will still read your codes? AUTO ZONE is not anywhere close to me. might not even be one in Canada
so the next easiest way is to pull the codes myself with-out a obd reader
is the obd 4 and 9
as for creating a problem not sure how im creating a problem. making it harder on myself yes.
Old Jun 5, 2016 | 10:30 PM
bvogel7475's Avatar
FYI for folks in California. Autozone won't read codes for you anymore because of a lawsuit. I bought a reader for 50 bucks and consider it a good investment.
Old Jun 6, 2016 | 06:20 AM
buy an OBD reader, OP.....
Old Jun 6, 2016 | 10:41 PM
Tomtwtwtw's Avatar
If you have Android phone - download free Torque app and buy a bluetooth OBD plug for 15 bucks off Amazon or Newegg and you're set. I assume iPhone has a similar app, but I don't own one so I can't personally verify.
Old Aug 15, 2021 | 02:37 PM
CSmoney28's Avatar
CSmoney28
Post
Reviving an old thread from the dead, I got this code but cleared and it didn't come back the B1276 code is Headlight SMALL position Circuit Malfunction.
Jbaum
2G RDX Problems & Fixes
Feb 20, 2024 07:27 PM
ricrx7
Feb 18, 2016 06:53 PM
DeathMetal
Feb 16, 2016 08:48 AM
mattyacura
Jan 25, 2016 06:00 PM
